Salas hotrodded blue DCB1 build
Old 27th October 2013, 10:14 AM   #3291
Corpius is offline Corpius  Netherlands
Corpius's Avatar
Originally Posted by AndrewT View Post
Corpius,
can I suggest a change to the mute operation?
Add a second resistor in series with and after the 220r output resistor. This extra resistor could be anywhere from 100r to 1k.
Move the S3 tapping from the output to the junction of the original 220r and the added resistor.
When ON, the switch shorts out the added resistor and the Receiver sees the lone 220r.
When MUTE, the switch connects to Audio Ground and the Source sees [220r+added resistor] as the load.
You could now change the original 220r to 100r, since this is no longer the only load when in MUTE.
Andrew, I totally missed your suggestion, but what exactly is the benefit from adding more resistance to the MUTE circuit?
CE-Designs.net
Old 5th November 2013, 01:32 PM   #3292
gadut is offline gadut  Indonesia
gadut's Avatar
Originally Posted by Salas View Post
This one is a real battle tank. You plan just a very little hot-rod current mode I guess.
yup, i think that using 2R7 will be a tinny current mode
while waiting my toroid package, play with some hand toys during holiday. hand saw aluminium plate to direct mount irfp's for the best heat transfer, and spray with golden paint. several holes are unused and not so rectangular saw result due to not so skillful me
Old 5th November 2013, 02:44 PM   #3293
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Very nice pictures. Confirm at least 15VDC on each polarity big filter capacitor with your Tx and mains combination at the times of day you usually sit for critical listening.
Old 5th November 2013, 03:38 PM   #3294
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
Nice heatsinks but their efficiency is severely reduced by mounting them horizontally.
Old 5th November 2013, 03:42 PM   #3295
Salas's Avatar
Fortunately he has gobs of area to spare towards non optimal orientation in this particular case. Also gadut make sure the insulation between MOSFETS and sinks is OK before firing it up. A DMM in continuity mode is enough of an aid for that check.
Old 5th November 2013, 04:08 PM   #3296
If you remember I took mine back down to 200mA as I couldn't hear any difference.
Old 5th November 2013, 04:18 PM   #3297
Salas's Avatar
I also remember many builders appreciating more current, I just gather its down to individual subjective choices in different systems so I will not officially recommend a particular choice regarding the bias or passive parts for that reason.
Old 5th November 2013, 04:36 PM   #3298
Each to their own of course.
Old 5th November 2013, 08:11 PM   #3299
davym is offline davym  Scotland
I've just been populating the DCB1 Black using the parts Tea-Bag sent me and the build guide wushuliu on Audio Circle put together. There are a few things I would like someone to clarify if possible please.
(1) Matched 2SK170BL - they came as 2 pairs along with the board which shoom kindly gave me. 1 pair were labelled 6.91/982 the other were labelled 6.92/883.
The build guide I used only concentrated on getting them orientated the right way. I fitted one matched pair one way round and the other pair the other way. I now see that near the start of this thread, Salas mentions that they should be placed in a particular order. Are mine close matched enough for this not to be an issue?
(2) I had 2 sets of large 6.5W wire wound resistors, 5 ohm and 10 ohm, I fitted the 10 ohm resistors. Will I need to heatsink the IRFP240/9240 to the enclosure or will a set of clip on heatsinks be enough to dissipate the heat at this power rating if I use a well ventilated enclosure?
(3) my transformer is 2 x 12v 50va (2.08 amp) I have not tested it yet but with my mains voltage it will probably output closer to 14v. Will this transformer be ok in this case or will I have to reduce the boards power consumption?
(4) I did not receive any 1R resistors, can I fit wire jumpers with this configuration?
Cheers
Davy
Old 5th November 2013, 08:23 PM   #3300
Salas's Avatar
1. If well matched the order is no big deal, you will revisit that only if your mV offset will be more than the averagely reported here.
2. Clip on will also do with 10R setting if of substantial size, not like those smallish ones we usually see LM317s on. Still, sinking on the enclosure is zero $ and looks elegant too.
3. 5V DC vin-vout at weaker mains hours is best to be a target. The reg will work even with 1V dif but its CCS will be compromised. There are Schottky diodes to use as well that can save some rectification losses due to their lower Vf, but they should be at least 60V reverse spec in your case.
4. Jumpers are fine. Those 1R serve a test point function for general reg uses irrelevant to your purpose.
You are welcome
Salas
Salas hotrodded blue DCB1 buildHide this!Advertise here!
dcb1 buffer with shunt reg. merlin2069er Swap Meet 0 3rd August 2010 05:25 PM
F2 and DCB1 parts selection - please advice! DQ Pass Labs 6 25th November 2009 03:20 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 07:40 AM
