Salas hotrodded blue DCB1 build
Old 16th June 2013, 05:54 PM   #3211
RKH is offline RKH  United States
Is the DCB1, as configured in Salas' post above, able to drive BOTH Balanced and SE outputs simultaneously?
Thanks,
Ryan
Lighten up while you still can ...
Old 16th June 2013, 06:29 PM   #3212
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Yes if they don't fall below 5K as a combined load.
Old 17th June 2013, 02:41 AM   #3213
Is it correct to determine the combined load as follows?:
(1/Zin1 + 1/Zin2)^(-1)
Where Zin is the input impedence. (I realize that balanced inputs may/will have different Zin than the SE inputs)
Sorry for the naive questions. Thanks for your patience.
Ryan
Old 17th June 2013, 02:51 AM   #3214
Salas's Avatar
Exactly like when paralleling resistors. Rtotal=(R1*R2)/(R1+R2).
Old 18th June 2013, 12:22 PM   #3215
johnwmclean is offline johnwmclean  Australia
FYI if anyones interested...
DIY Salas Hot -Rodded Balanced DCB1 Buffer FS
Old 18th June 2013, 03:24 PM   #3216
Salas's Avatar
That was one of the most spectacular DCB1 balanced builds here. Sad to see it on sale... Has no function in your current setup? It would need a volume control and a selector for most guys though.
Old 18th June 2013, 09:26 PM   #3217
Hi Salas,
Just running into some financial difficulties.
I used digital volume and only one source...
Many thanks,
John
Old 18th June 2013, 10:05 PM   #3218
mantha3 is offline mantha3  United States
John,
Nice DIY Audio Equipment sells well on AudiogoN - The High-end Audio Community... Just another place to post this.
A work of art I'd say.
Old 21st June 2013, 05:07 PM   #3219
harmolodics is offline harmolodics  United States
Default Powering Multiple DCB1
With multiple DCB1 circuits, is it recommended that each has its own PSU and transformer? Or can additional DCB1 circuits be adequately powered from the SalasDCB1 board?
I'm looking into a buffered 2-way crossover that would use 3 DCB1.
Old 21st June 2013, 06:35 PM   #3220
Salas's Avatar
Use 30VA separate trafos and 200mA CCS setting each in own regs populated for best separation config. Using 3mm floor of a medium size box for sinking can avoid separate sinks bulk and cost and it will suffice. Use silpads.
Salas hotrodded blue DCB1 buildHide this!Advertise here!
dcb1 buffer with shunt reg. merlin2069er Swap Meet 0 3rd August 2010 06:25 PM
F2 and DCB1 parts selection - please advice! DQ Pass Labs 6 25th November 2009 04:20 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 08:40 AM
