Salas hotrodded blue DCB1 build
Old 1st May 2013, 02:22 PM   #3021
dimkasta is offline dimkasta  Greece
dimkasta's Avatar
I was planning to route a hole in wood big enough to contain the transformer with some air, cover the hole edges with copper and ground it and then completely flood the hole with wax with the transformer in it.
Too many projects... so little time...
Old 1st May 2013, 02:23 PM   #3022
mantha3 is offline mantha3  United States
Originally Posted by RKH View Post
What are folks in the North America using for power supply transformers? I see ANTEK is re-stocking after their factory fire, so that is an affordable option. Has anyone used Plitron or Primrose? Any r-core ideas (with suitable VA)?
Thanks,
Ryan
I purchased one of these (Model: R80-53)
100W R-Core Transformer 115V//230V ,Pre amplifier / DAC
I wanted to try an RCORE. I saw some others had used this one 100VA and then also the 50VA one whcih is a bit cheaper. The shipping is kind of harsh.
go back about 20 - 30 pages and some talk on this RCORE I speak of.
Old 1st May 2013, 02:48 PM   #3023
pinnocchio is offline pinnocchio  Canada
pinnocchio's Avatar
I can't remember if I did or not share with you my DCB1 balanced build so here it is!
My two modules fully assembled
Here's the heatsinking! Lots of it... I'm currently running it with 3R3 resistor but I planned for 1R so hence all the heatsinking. Base plate holding the heatsinks is 0.25" thick
Here the base plate is mounted in a Par-Metal chassis. Only one transfo for now for testing.
I've added a Goldpoint balanced stepped attenuator and a Goldpoint source selector.
Here's an ensemble view showing everything plus the back panel. I'm also using AMB switch driver for power on the beast!
Here's the finished product!
This was a great fun building but an even greater one listening to the music!
Thanks Salas and Tea-Bag for this great project!
Do
PREAMPs : Bal AMB α10 + JC-80 | Bal DCB1 | Bal LDR3x | AMPs: AMB β24 | USSA3 & 5 | FO v1.4 | TGM8 | VZ Audio NS OPS | NX Amp | FC-100
DACs : TPA Buffalo II + OPC's NTD1 I/V | JLsounds | Mirand AK4490 + Discrete Output Speakers : Troels Gravesen ATS-4 | Sagwee LT V3
Old 1st May 2013, 03:27 PM   #3024
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
One expensive and very well crafted example! Congratulations!
Old 1st May 2013, 04:22 PM   #3025
pinnocchio's Avatar
Thanks!
I must admit I truly love the DCB1. Never had a soundstage that wide and deep before! Really good!!!
Ciao!
Do
Old 1st May 2013, 04:48 PM   #3026
@pinnocchil
Impressive and well built. I'm sure you will get many many years of service out of that!
What is the silver spool to the left? Did you wire with .999 pure silver?
Old 1st May 2013, 06:18 PM   #3027
pinnocchio's Avatar
Originally Posted by mantha3 View Post
@pinnocchil
Hi Mantha3,
Thanks for the comment! I do hope to get many years of listening with it. I'm planning to change the resistors from 3R3 to 1R in the coming weeks to test the sound difference if any.
The spool that you see is tin, copper, silver then I have a spool of 37/63, a spool of Johnson's IA-423 (ternary eutectic) and a little bit of Mundorf Silver/Gold solder.
I don't use much of the spool you see on the picture anymore since it is harder to melt, need almost 400 degrees...
Do
Old 2nd May 2013, 11:17 AM   #3028
Neville is offline Neville  United States
I have not been able to find an answer yet to my question so here goes : If I were to use either the Mezmerize or Hypnotize pcb as a preamp and not dedicated power, could I add a 3 pole terminal block where its marked V+, G, V- and tap off that to power other kit? From other posts and my findings it should be between 9v and 10V.
Thx
Old 2nd May 2013, 11:29 AM   #3029
R.I.P.
yes.
The DC supply in the Mez & Hyp has a lot of spare capacity to supply other low current circuits.
There is also spare capacity in the unregulated DC after the smoothing that can be used in other circuits. The 3pin regulator and relays are an example of using some of this spare capacity (on one polarity).
regards Andrew T.
Old 2nd May 2013, 11:39 AM   #3030
Originally Posted by AndrewT View Post
yes.
Will it have any negative impact on parts downstream or sound quality? In my case I would use regulated but could you be so kind as to pin point where on the pcb or parts I could tap off if I did want unregulated?
Thx
Salas hotrodded blue DCB1 buildHide this!Advertise here!
dcb1 buffer with shunt reg. merlin2069er Swap Meet 0 3rd August 2010 05:25 PM
F2 and DCB1 parts selection - please advice! DQ Pass Labs 6 25th November 2009 03:20 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 07:40 AM
