Salas hotrodded blue DCB1 build - Page 295 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 26th March 2013, 05:21 PM   #2941
stajo is offline stajo  Sweden
Originally Posted by Praudio View Post
So at first ; what I am looking for ; what components I must suspect.
Where is DCB1 diagram on DIY
Thanks for your help.
Check diodes w battery or so first. They easily go south with to much solder heat. Then start measure voltages over comps from PSU and down. Diagram in post #4 this thread.
Old 27th March 2013, 07:38 PM   #2942
atupi is offline atupi  Romania
I've just finished my DCB1 build and sounds really good from the first power up. One thing is not clear to me, what cap to install in the middle of pcb?
I see there 0.22uf but also 100uf elco.
What's the idea of two caps and what is the best choice ?
Adrian
Old 27th March 2013, 07:52 PM   #2943
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
non hot rod design used 100uf.
Hot rod style uses .22uf typically, but it can be somewhat bigger or smaller.
Salas Boards GB 2017#1 Click Here to Sign Up! | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards Out of stock
Old 27th March 2013, 07:58 PM   #2944
As i have 10R resistors installed so is hot rodded
Rega RP-1/Simplistic RIAA by Salas/ DCB1 clone/ MyRef Fremen Edition/FC-100/ XTZ 99.26 MkII speakers
Old 27th March 2013, 08:13 PM   #2945
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Try film cap, try good electrolytic cap, and decide for your system with own ears is best diy.
Old 1st April 2013, 06:25 PM   #2946
Try polystyrene caps (Styroflex in Europe) - to my ears the offer the right combination of clarity and warmth.
Today a friend and I managed to use an old heatsink I for to finish hotrodding. Moved down from 3.9R via 1.95R to final 1.3R (= a litte more than 1A). The sound changed is pretty breathtaking. The presentation gets more solid, you get a lot more natural timbres (colours) and any hint towards harshness disappears. This preamp is absolutely unbelievable.....IMHO.
dubai
Old 1st April 2013, 06:39 PM   #2947
Tea-Bag's Avatar
Here is my homely DCB1 facing sideways running 2R current, driving big_A speakers with F6 at a fellow member and neighbors house.
Good times.
Old 1st April 2013, 09:14 PM   #2948
Looking good -that's what I'll need next - a propper chassis......
Old 1st April 2013, 10:34 PM   #2949
mantha3 is offline mantha3  United States
Tea-Bag,
What chassis is that? Mind sharing the source?
Old 2nd April 2013, 01:16 PM   #2950
pinnocchio's Avatar
Originally Posted by mantha3 View Post
Tea-Bag,
You can get nice chassis from the DIYaudio shop
Full width with 40mm Heatsinks - Chassis
You can also buy them directly from Modushop in Italy (Pesante Dissipante section)
modushop.biz
Also on Ebay
FS 430 Full Aluminum Power Amp Enclosure Case External Size 430mm 150mm 314mm | eBay
There's also many more sources
Ciao!
Do
PREAMPs : Bal AMB α10 + JC-80 | Bal DCB1 | Bal LDR3x | AMPs: AMB β24 | ExtremA | FO v1.4 | USSA5 | TSSA | Telos 390 Clone | NX Amp | FH9hv
DACs : TPA Buffalo II + OPC's NTD1 I/V | JLsounds | Mirand AK4490 + Discrete Output Speakers : Troels Gravesen ATS-4 | Sagwee LT V3
dcb1 buffer with shunt reg. merlin2069er Swap Meet 0 3rd August 2010 05:25 PM
F2 and DCB1 parts selection - please advice! DQ Pass Labs 6 25th November 2009 03:20 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 07:40 AM
Copyright 1999-2017 diyAudio
