Salas hotrodded blue DCB1 build
Old 16th March 2013, 09:17 AM   #2931
bambadoo is offline bambadoo  Norway
O yes.. That was a couple of years ago - Great amps.. A lucky new owner has them..
Old 16th March 2013, 09:45 AM   #2932
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Real size speakers, that's good.
Old 25th March 2013, 01:01 AM   #2933
dimkasta is offline dimkasta  Greece
dimkasta's Avatar
Nick do you have an opinion for using a single 0,47uF FT3 teflon instead of K75-10 2,2uF bypassed by 0,1uF as output?
Provided that my amp is 220k input, so there should be no bass issue with the 0,47uF cap...
Old 25th March 2013, 09:03 AM   #2934
Salas's Avatar
FT3 is good on its own you should try and decide. The phase is going to turn 5deg @ 20Hz and the -3dB point will be just under 1Hz. With the previous value there was almost no phase turn @ 20Hz. Those are the typical differences.
Old 25th March 2013, 12:48 PM   #2935
mantha3 is offline mantha3  United States
This would be a nice option on a Khozmo attenuator... I think this is a new option
Old 25th March 2013, 05:47 PM   #2936
oneplustwo is offline oneplustwo  United States
oneplustwo's Avatar
I'm thinking about building in a boozehound phono preamp with a hotrodded DCB1. Any reason I can't tap into the shunt regulated power supply to power the phono? It's happy with anything between 12V and 24V DC so I think this would be ok. All I would have to do is add a switch for the line/phono RCA connectors.
My Projects
Old 26th March 2013, 03:37 PM   #2937
dimkasta's Avatar
It s also time for me to start testing output resistors, so Niko I need your help better optimizing their value.
If I remember correctly from one of your previous posts, you suggested feeding a wave into the buffer and checking for oscillations. If everything seems ok then try to lower the output resistor values (and output impedance) until oscillations appear, and then go a bit up until it's fixed.
Do you mind sharing a bit more about this testing rig? What should be attached to the output? Cable only? amp? dummy load equal to amp impedance? What should the test input wave be?
I have no generator, so I will have to use something like a plain wave generator either from my pc or my phone.
Also, could I use trimmers to find the lower value for the resistors?
Are these lower values dependent only on the input impedance of the amp, or by the interconnects as well?
Thanks again for your invaluable help
Old 26th March 2013, 03:44 PM   #2938
Salas's Avatar
You need a clean square wave generator in the audio band at least with the fastest rise time you can have, the IC cables to be used, a dummy of the amp's input resistance and capacitance to terminate the IC cable. You need not see ringing on the edge of the square wave as you test lower output series resistor values.
Old 26th March 2013, 03:45 PM   #2939
Salas's Avatar
The DCB1 is 10V out though.
Old 26th March 2013, 04:57 PM   #2940
Praudio is offline Praudio
In trouble with 2 hotrodded DCB1
Built 4 during last 3 months : two were perfect at first fire up and 2 others were not.
All semi conductors come same batch:BC550C,BC560C ,BC517G and ixys diodes from Digi-Key
Transformers 14-0-14 120va;and get 20.5VDC on can, resistors 10 ohm 5w , diodes from Ed.Lafontaine, IRFP240/9240 from an other DIY member etc. , 2sk 170 from Spencer
On one DCB1 the 5 diodes on 9240 side don't light on ; the other the 5 +3 diodes on same side (9240) don't light:
So at first ; what I am looking for ; what components I must suspect.
Where is DCB1 diagram on DIY
Thanks for your help.
Praudio
Salas hotrodded blue DCB1 buildHide this!Advertise here!
dcb1 buffer with shunt reg. merlin2069er Swap Meet 0 3rd August 2010 05:25 PM
F2 and DCB1 parts selection - please advice! DQ Pass Labs 6 25th November 2009 03:20 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 07:40 AM
