Salas hotrodded blue DCB1 build
Old 10th March 2013, 03:49 PM   #2911
LucasAdamson is offline LucasAdamson  United Kingdom
LucasAdamson's Avatar
^ Yup, what he said!
Lucas
Old 11th March 2013, 08:17 AM   #2912
dtses is offline dtses
cheers,
thanks! I'll check primaries today in the evening, I though that only secondaries should be phased.
Just to mention that if there is no load, trafo does not produce any audible hum.
Old 11th March 2013, 09:48 AM   #2913
R.I.P.
Use a bulb tester !
regards Andrew T.
Old 12th March 2013, 08:26 AM   #2914
stajo is offline stajo  Sweden
Originally Posted by buzzforb View Post
RESISTORS Precision (through hole) 3ppm/C wirewound squaristor GR102 / GG102 series
I dont think the exact numbers are a big deal. 250 should be fine, but ask Salas to make sure. I am by no means saying it will make a profound change, but at least they measure really well.
Has anybody used those for this purpouse? 200 or 250 ohms?
Staffan
Old 12th March 2013, 08:46 AM   #2915
Originally Posted by stajo View Post
Are you sure that you have connected primarys right?
First make sure you know which ends belongs to the same windings.
Then you need to connect the windings in series and they need to be in phase, meaning the "start" on winding number 2 connects to the "end" of winding number 1. If you connect the second winding the other way then the the first they work against each other and the trafo hums and gets warm very quick.
Staffan
the windings are in phase, just as you said and is described here.
So I tried with only one trafo and got similar hum, then I put it out of the metal box and vuala, it has disappeared. Seems the problem is in my rather small case. However if I place the trafo a bit higher (2-2.5cm) the nasty hum vanishes. I think I'll give it few tries more with a closed lid and see if the issue still persists. In case yes, need to go for some decent toroids then. Bad thing is that I'm too restricted in space.
Just to mention that it's an old pic and I know that trafos shouldn't be placed so close to each other
Originally Posted by AndrewT View Post
Use a bulb tester !
Andrew, I need to buy a bulb first
Old 12th March 2013, 09:04 AM   #2916
And definately not that close to the signal circuit eother, needless to say maybe
I think you have 2 choices: either put the trafo in a separate box, outside this, or find a small enough trafo that fits your box and your needs, place it to the right as far away from the buffer circuit as possible. Preferably with some grounded iron wall between.
Btw all inductors, spools, trafos etc are in some way affected to metal, magnetic material close by and changes their behaviour. Those should be made for mounting on metal but now they are also interacting. Or just bad trafos for the conditions.
GL
Staffan
Old 12th March 2013, 09:28 AM   #2917
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Connectors and cables to the Mosfets and the gate stoppers still on board than on gate pins and this build still looks stable for rail voltage on a scope?
Old 12th March 2013, 09:33 AM   #2918
Salas's Avatar
If by lifting them up some interaction with their core and the metal case stops to getting them humming plus there is no hum and buzz in the audio you are done for practical purposes. If its perfect or not it takes hi bit FFT to see. Many good pc soundcards will suffice.
Old 13th March 2013, 08:34 AM   #2919
thanks, Staffan, I see what I can do. I have a 30VA toroid that does not produce any hum at all, perhaps that would be a good start then.
Anyway, I'm a bit disappointed, I thought it would be a nice compact oven including decent step attenuator and good components, but ended up eventually most likely with a need changing chassis as I do not accept separate box for PS and dreamed about >1A current
haven't attached the scope yet. The output voltage is stable and equal till 0.00 on both channels.
Resistors will be relocated as you already advised earlier few month ago to some other member here
Old 13th March 2013, 12:53 PM   #2920
mantha3 is offline mantha3  United States
would running the wire leads from the DBC1 to the 2SK170 under the power transformer make for some issues? Hum etc?
Salas hotrodded blue DCB1 buildHide this!Advertise here!
dcb1 buffer with shunt reg. merlin2069er Swap Meet 0 3rd August 2010 05:25 PM
F2 and DCB1 parts selection - please advice! DQ Pass Labs 6 25th November 2009 03:20 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 07:40 AM
