Go Back   Home > Forums > Source & Line > Analog Line Level
Old 3rd March 2013, 07:10 AM   #2841
stajo is online now stajo  Sweden
Originally Posted by mantha3 View Post
For the "take a +12V auxiliary line from there" How do I ID the spot on the PCB where you are talking about?
Maybe you could use your meters as power on led instead of the led, just lowering the current resistor a bit.
Old 3rd March 2013, 12:39 PM   #2842
mantha3 is online now mantha3  United States
I may have to... The bummer is that I already got the illuminated power switch.
Here is the tech sheet on the power switch... It looks like it does not pull much at all...
Illuminated Power switch
Old 3rd March 2013, 12:51 PM   #2843
The button probably contains an ordinary LED and has a built in resistor for 12 V feed. 10-30 mA would be my guess. Do you feed the power on LED with that, and kept 2k2 resistor? Then I guess it doesnt light up the house? And you could measure the current by taking the voltage drop over the 2k2 res.
/Staffan
Old 3rd March 2013, 12:56 PM   #2844
I am leaning towards hooking up both the Illuminated power switch and the VU meeter board to this spot:
I do have a heat sink coming for the 7812... I am buying a kit from Teabag. Having the heatsink on the 7812 perhaps I can push having both the Illuminate power switch and the VU meeters? Salas mentioned this 7812 is the breaking point I think...
Old 3rd March 2013, 01:02 PM   #2845
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
The sink will give you more spare current leeway before cooking that reg chip. How much exactly I can only tell when having the sink's full spec.
Old 3rd March 2013, 01:04 PM   #2846
To my knowledge a 7812 takes well over 1 A sinked. You see were you have gnd. Its the copper lane that connects the centerpin of 7812 and the power on LEDs cathode. Between LED and the 12 V output from 7812 output pin you have a 2k2 current limiting resistor.
Dont think the copper lanes are designed for 1 A tho, but that you wont need.
Staffan
Last edited by stajo; 3rd March 2013 at 01:05 PM. Reason: Yea, Salas posted when I wrote
Old 3rd March 2013, 01:09 PM   #2847
I think this is the sink Teabag sends with his kits:
Heat Sink Specs
Old 3rd March 2013, 01:12 PM   #2848
PS - Teabag has upped the capacitors on the kits to 10,000uf 35v from 4700uf 25v... Not sure if that added capacitance changes things..
Old 3rd March 2013, 01:16 PM   #2849
Not in this case but its a good thing for hotrodders who does 2*15 V trafos. 25 V is licking its limits there since its ripple on the ingoing rectified 21ish voltage. Sure it is 2 times 10 000 per rail? They will most likely be big.
Staffan
Old 3rd March 2013, 02:03 PM   #2850
Salas's Avatar
Heat Sink Specs
It will rise 20c/0.5W. I would not ask the chip for more than 500mA on that sink with circa 20V raw dc in we got here.
dcb1 buffer with shunt reg. merlin2069er Swap Meet 0 3rd August 2010 05:25 PM
F2 and DCB1 parts selection - please advice! DQ Pass Labs 6 25th November 2009 03:20 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 07:40 AM
Copyright ©1999-2013 diyAudio
