Salas hotrodded blue DCB1 build - Page 270 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 13th February 2013, 06:29 PM   #2691
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Faked American Fets for K170 usually have some symbol in there that the dodgy fellas leave there and only grind and change the face print. That is why I asked you to check. Another subtle clue is at the pins where they enter the plastic. If genuine Toshiba you can see a hint of copper color that is not completely tinned.
Old 13th February 2013, 06:40 PM   #2692
stajo is online now stajo  Sweden
My son just asked me why I'm taking pictures of stupid electrical stuff. "Who want to look at those?" I had to confess that I'm a nerd
Old 13th February 2013, 06:43 PM   #2693
Salas's Avatar
Tell him you teleport silicon souls to Greece for a holiday.
Old 13th February 2013, 06:48 PM   #2694
Funny I just helped him construct a teleport glyph in Minecraft. I wish it had lead to Greece tho. Sorry for the OT.
Old 15th February 2013, 07:38 AM   #2695
oneplustwo's Avatar
Anyone ever try feeding one of these with laptop power supply bricks? Most are 19v which might be a little low, but perhaps less losses since you could skip the rectifiers. Just a thought since I have a couple lying around.
My Projects
Old 15th February 2013, 11:57 AM   #2696
Salas's Avatar
Capacitors coupled B1 takes monopole, this one takes bipolar PSU. Better avoid switching PSUs anyway unless it is essentially practical to use one. And better filter it further. Even DC to DC converter regs produce traces of their inner works along their DC output.
Old 15th February 2013, 05:09 PM   #2697
Salas's Avatar
...And here is an output noise example from some LM2596 buck regulator PCB I had around. Has the datasheet output filtering configuration. 10V input 5V output -no load- in this take. High efficiency step down switcher yes, steady DC output yes, much current capability yes, clean enough for hi-res audio PSU use rather no.
Old 17th February 2013, 10:35 AM   #2698
That's pretty nasty looking. Thanks for sharing.
Michael
Old 17th February 2013, 10:40 AM   #2699
Salas's Avatar
That ripple goes to 60mV peak to peak when it gives 1A. It receives linearly regulated DC input in the test, I don't know if it adds even more stuff if fed from just bridge and capacitor. Typical laptop bricks can be worse or bit better but that's the deal more or less. Silent SMPS are costly and sophisticated. Like those for Hypex Ncore amps.
Old 17th February 2013, 10:52 AM   #2700
I have been following the nCore thread for some time (a future project). The consensus is that the nCore SMPS is as good as a linear PS. Expensive, but it proves that a SMPS can be made well enough for audiophile applications.
Michael
dcb1 buffer with shunt reg. merlin2069er Swap Meet 0 3rd August 2010 05:25 PM
F2 and DCB1 parts selection - please advice! DQ Pass Labs 6 25th November 2009 03:20 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 07:40 AM
Copyright 1999-2017 diyAudio
