Go Back   Home > Forums > Source & Line > Analog Line Level
Old 1st February 2013, 03:28 PM   #2641
schubert's Avatar
Yeah, it gets complicated. Good luck, and keep us posted!
Old 1st February 2013, 06:29 PM   #2642
stajo is online now stajo  Sweden
Originally Posted by Salas View Post
*If someone is perfectionist about matching the Verf LED gangs of 5, the best maniac party trick is to use a *12V battery, connect gate and source together in the specific 2SK170s that are going to feed those strings (those Jfets above 1R), feed (+) to the drain, connect g&s node to LEDS string, return string's other end to (-), and swap between enough glow bugs until you got 2 total across 5 LEDS Voltage matches, each to its own Jfet. For the cherry on the cake set DVM that measures diode drop (some got it) and find 2 Vbe matched BC550 & 560.
Practical benefit? Next to nothing. Aesthetic ritualistic benefit? Priceless.
*9V,1.5V,1.5V batteries in series that are common types, maybe already in remote controls on the coffee table, will do for 12V total. And don't post pics from the parking space tapping on the car's stuff.
I might think sometimes that you shouldnt tell thise maniac partytricks because one day someone might take you seriously Salas. Ofcourse I'm just posting those pix educationally to what could happen if someone really took you seriously.
Staffan
Old 1st February 2013, 08:55 PM   #2643
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Old 2nd February 2013, 08:14 AM   #2644
Good choices.
If you really got space in the box, I would recommend 4 monstrous 2.2uF Russian capacitors to make two 4.4uF pairs bypassing each pair with 0.1uF monstrous Russian Teflon. I believe they exceed the German silver in oil type even when in that config for far far less.
Salas
I replaced obbligato premium gold 4.7 uF with K75 only 2.2 uF (no place for other 2.2 uF) bypassed FT-3 0.1 In my coupling application - I get enough bass do you recommend to use other 2.2 cap with FT-3 0.1
there are imrovement In highs but I think that the sound Is somehow aggresive and In your face - can that effect be fixed when caps get burned In
Old 2nd February 2013, 09:35 AM   #2645
Salas's Avatar
That combination is smooth, weighty, and transparent in my experience. What is the amp and speakers you play music with? To better quantify the caps signature to your liking and system tonal synergy let the K75 play alone, just lift one link to each FT-3. What are the perceived changes? K75 alone is rather rounder and darker. If the tone is still upfront you may need match your former uF value first to say for sure.
Old 2nd February 2013, 09:41 AM   #2646
thank you for reply
I use PCM63 - modifyed Pass D1 I/V I/U stage D1 clone with 2sk389 finetuned... - stepped 20K pot - UGS V3 - F5 - Infinity Kappa 90
Old 2nd February 2013, 09:51 AM   #2647
Salas's Avatar
Is there gain in the UGS V3?
Old 2nd February 2013, 10:10 AM   #2648
I use that schema UGS adventures
Old 2nd February 2013, 10:16 AM   #2649
Salas's Avatar
There is gain then. Which is good for F5 on your speakers. OK do the K75 alone test first. Some combination should work best for you. Do you see space for your Obbli plus the K75 in your box for another experiment with higher coupling uF value?
Old 2nd February 2013, 10:59 AM   #2650
thank you for support
well I will find place
now I only use 2.2 K75 bypassed with 0.1 FT-3 as there Is plenty of bass
do you think It will be right to add other 2.2 uF K75 and after that adding obbligato which Is 4.7 uF
dcb1 buffer with shunt reg. merlin2069er Swap Meet 0 3rd August 2010 05:25 PM
F2 and DCB1 parts selection - please advice! DQ Pass Labs 6 25th November 2009 03:20 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 07:40 AM
Copyright ©1999-2013 diyAudio
