Salas hotrodded blue DCB1 build - Page 261 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 26th January 2013, 09:30 AM   #2601
Move the gate resistor with the FETs.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 26th January 2013, 10:56 AM   #2602
So I lift up from the board the 470Rs?
Old 26th January 2013, 01:10 PM   #2603
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Yes, they should follow the physical gate pin close.
Old 28th January 2013, 03:27 PM   #2604
pinnocchio's Avatar
Quick question for you guys.
I have made myself a balanced version of the DCB1 and I have 3 Balanced XLR and 2 SE RCA input and on the output I have 1 Balanced XLR and one SE RCA.
I'm using one DCB1 per balanced channel and when using it in SE I do the same thing but connect the signal to +phase and ground to signal ground.
I wanted to know on the RCA input, if I should shunt the antiphase (-phase) to ground or put in a resistor for a fake load since I'm only using one channel per side in SE mode.
Do
PREAMPs : Bal AMB α10 + JC-80 | Bal DCB1 | Bal LDR3x | AMPs: AMB β24 | ExtremA | FO v1.4 | USSA5 | TSSA | Telos 390 Clone | NX Amp | FH9hv
DACs : TPA Buffalo II + OPC's NTD1 I/V | JLsounds | Mirand AK4490 + Discrete Output Speakers : Troels Gravesen ATS-4 | Sagwee LT V3
Old 28th January 2013, 03:50 PM   #2605
Salas's Avatar
All XLR to RCA converter plugs ground it but it can up THD in the balanced source so better terminate it with ~600 Ohm for the redundant phase.
Old 28th January 2013, 03:55 PM   #2606
pinnocchio's Avatar
OK, thanks!
I'll terminate the -phase to ground with a 600 ohm resistor.
Do
Old 29th January 2013, 07:58 AM   #2607
hi,
few quick questions regarding two 35VA pcb 15v transformers I have paralleled. The adjustment R is 2 ohms making it 1.77VDC and 1.92VDC on the rails. Wattage meter shows about 48VA of constant consuming. So as advised by Andrew I'm still in a safe zone
1. Trafos have 2x110v primaries, is it safe to use them? Checked the mains during the week and it varies from 218 till 228v.
2. I get quite audible hum when I'm close to them (about 10cm). Could that be reduced somehow? Will mu-metal be helpful here?
Old 29th January 2013, 08:53 AM   #2608
Default Oh my god
You can not place transformers so near the pot. It will off course result in hum. The 2x 110 is no problem when coupled i series.
Old 29th January 2013, 10:15 AM   #2609
just to clarify, the pot is just there hanging and the buffer is not connected to any source. By the hum I meant physical hum from transformers.
Old 29th January 2013, 11:17 AM   #2610
ok then you have to buy new transformers .
dcb1 buffer with shunt reg. merlin2069er Swap Meet 0 3rd August 2010 05:25 PM
F2 and DCB1 parts selection - please advice! DQ Pass Labs 6 25th November 2009 03:20 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 07:40 AM
Copyright ©1999-2017 diyAudio
