Salas hotrodded blue DCB1 build - Page 260 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 18th January 2013, 01:30 PM   #2591
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
The Mosfet Vgs rises with higher current setting and nears the particular Leds total. Either stronger Vf Leds or smaller setting resistors will do the setting you aim at. If you got enough Vin-Vout then all is a matter of particular semis characteristics. How high a DC you can measure across the bigger smoothing electrolytics?
Old 18th January 2013, 01:49 PM   #2592
kroyin is offline kroyin  India
Thanks Salas, the Caps are flush mounted on PCB and measuring them without unmounting is not possible.
For the time being I have used 2 1r in series pushing bias to ~500mA
Old 18th January 2013, 01:58 PM   #2593
Salas's Avatar
With 15VAC Tx should be enough if your mains don't sag much anyway. Listen at 500mA and tell us if you can hear any better music.
Old 18th January 2013, 08:20 PM   #2594
Renron is offline Renron  United States
Renron's Avatar
Good thing it's still cool in India. 500mA......
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3
"I fired up the prototype. Literally." The Prophet Pass.
Old 19th January 2013, 03:49 PM   #2595
Too much of the good thing is not good for me ;-).
500mA for me adds dollops on bottom taking chunks out of mid & top.200mA for me.
Hey its winter :-)
And where in the world would you get the last real stand of the royal Bengal tiger (sunderban - 70miles)....drive on seabeach (90 miles)
Sip you favourite poison while seeing the sun setting on third highest peak of the world (300 mile)
Old 19th January 2013, 03:58 PM   #2596
KatieandDad's Avatar
I didn't notice any real difference after 300mA. I'm sure that some guys hear a difference because they have paid for it.
You shouldn't lose any detail though unless trafo isn't big enough to supply the current.
Old 19th January 2013, 04:09 PM   #2597
<Delete duplicate post>
Old 20th January 2013, 09:33 AM   #2598
Hello,
I have two matched quartet of 2sk170: 9.11-9.10 / 9.03-9.04 (BL grade) and 6.07-6.07 / 6.18-6.18 (these are GR, but fall into the >6mA range). Which quartet should I use?
The other unmatched six around which values are better?
Old 20th January 2013, 09:46 AM   #2599
Salas's Avatar
The BL. 7-9ma is good compromise for their gm and dissipation as used here.
Old 26th January 2013, 07:55 AM   #2600
Thanks Salas.
I also would like to add about 2cm of wire to the legs of the MOSFETs, to spread them a bit more on the sinks, and to keep the sinks detached from the board. Oscillation problems or I'm still in a safe range?
dcb1 buffer with shunt reg. merlin2069er Swap Meet 0 3rd August 2010 05:25 PM
F2 and DCB1 parts selection - please advice! DQ Pass Labs 6 25th November 2009 03:20 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 07:40 AM
Copyright 1999-2017 diyAudio
