Salas hotrodded blue DCB1 build
Old 11th January 2013, 09:02 PM   #2551
pinnocchio is offline pinnocchio  Canada
pinnocchio's Avatar
Originally Posted by Salas View Post
Well done guys, enjoy. Pinnocchio, impressive build.
Thanks!
PREAMPs : Bal AMB α10 + JC-80 | Bal DCB1 | Bal LDR3x | AMPs: AMB β24 | USSA3 & 5 | FO v1.4 | TGM8 | VZ Audio NS OPS | NX Amp | FC-100
DACs : TPA Buffalo II + OPC's NTD1 I/V | JLsounds | Mirand AK4490 + Discrete Output Speakers : Troels Gravesen ATS-4 | Sagwee LT V3
Old 11th January 2013, 10:40 PM   #2552
MASantos is offline MASantos  Portugal
What is the input impedance of the DCB1?
I am planning on using the o2 relay based att from amb.org and need the input impedance of the next stage for resistor calculation.
Also is 25k a good value for the attenuator impedance? I've read that 20k is the best option but would 25k reduce the overall performance of the dcb1?
Old 12th January 2013, 01:57 AM   #2553
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
220K input is what the pot drives. 25K pot is not that bad. Use even 10K if your sources can take it.
Old 12th January 2013, 02:08 AM   #2554
Erlend Sæterdal is offline Erlend Sæterdal  Denmark
Default 220 kohm input and without pot.
Hi in our Hificlub we will use the buffer only for high impedanse sources. One member have a Audionote dac with 0,47 uf. as coupling caps. That is far to small for ordinary sources. Is it ok with the 220 kohm only and no pot ?
Old 12th January 2013, 02:21 AM   #2555
The sources will be a simplistic riia or similar phono stage, some dac to be decided yet, ocasional iphone or ipad. No old tuners or tape decks so would 10k be acceptable?
Old 12th January 2013, 02:58 AM   #2556
Salas's Avatar
Don't know the output impedance of Apple gadgets. Find the one source's Zo value to be used that has the highest output impedance and use 10x pot that. If that means more than 25K, avoid that source. SNJFET RIAA is OK with 10K. You will have to augment its output coupling cap accordingly though.
Old 12th January 2013, 02:58 AM   #2557
Salas's Avatar
Yes.
Old 12th January 2013, 06:02 AM   #2558
kroyin is offline kroyin  India
Guys I cannot hear the relay click (12v relay note is jumpered)
Vout is +-9.3v
V across 10R resistors is 1.3V
All led glowing
Vgs of all mosfets 3.9V (+-30mV)
Input output not connected
No DC offset no voltage across relay diode.
What do I look at?
Thanks in advance
Old 12th January 2013, 06:43 AM   #2559
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
I had the issue that the timing circuit was not triggering correctly.
Try measuring the voltage across the relay coil to see if it should have operated.
Old 12th January 2013, 06:55 AM   #2560
Hmm when I touch multimeter leads across B & C of bc517 relay clicks
Does not look a cold solder or short on inspection
Salas hotrodded blue DCB1 buildHide this!Advertise here!
dcb1 buffer with shunt reg. merlin2069er Swap Meet 0 3rd August 2010 05:25 PM
F2 and DCB1 parts selection - please advice! DQ Pass Labs 6 25th November 2009 03:20 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 07:40 AM
