Salas hotrodded blue DCB1 build
Old 9th December 2012, 02:10 PM   #2511
palmito is offline palmito  United States
palmito's Avatar
Originally Posted by Salas View Post
A parallel output with 100 Ohm buffer resistors in line.
I have double outputs to the amp and a self powered subwoofer, didn't use the 100R resistors. Seems to sound ok so far, have had no issues with it. Should I put the 100R resistors in anyaway?
Old 9th December 2012, 04:11 PM   #2512
Renron is offline Renron  United States
Renron's Avatar
I was wondering the same thing. Wouldn't the 100R just act like an attenuator?
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3
"I fired up the prototype. Literally." The Prophet Pass.
Old 9th December 2012, 04:51 PM   #2513
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
I have had my 100R in for years, no gain problems. And not just in this project. I imagine it will tweak impendence a bit. I've had some very large resistors in line 10k on input before - you can calculate the voltage drop and gain with a t-network. Do not know the formula off the top of my head.
you can always do without, unless you run into some issues- then put them in.
Some Salas Boards In stock, PM | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards PM for sign up | Sony VFET CSX2 AL boards Shipped | Vishay/Harris MOSFETs Click Here to Sign Up!
Old 9th December 2012, 06:10 PM   #2514
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
If there are no oscillation issues in a system without the buffer resistors, then leave it at that. Their purpose is to counteract against more capacitance by the double cable runs towards the biamping configuration.
Old 9th December 2012, 06:12 PM   #2515
R.I.P.
the reason TB has not notice any gain issue, or more correctly lack of gain is due to attenuation =
20*[log 10k/{10k+100}] = 20*log0.99009 = 20*(-0.004321) = -0.086dB
The attenuation created by the 10k input impedance is less than 0.1dB.
If there was a 100k stage to be fed by the DCB1, then the attenuation <0.01dB, (actually -0.00868dB).
Stop worrying about next to nothing.
regards Andrew T.
Old 7th January 2013, 09:00 AM   #2516
bambadoo is offline bambadoo  Norway
Hi all.. Thanks for this great thread.
I received Tea Bags package some time before christmas and started soldering yesterday..
Some pics attached.
I have a couple of building questions:
As some people has mentioned before. The direction of the led's. I got a bit confused and have not soldered them yet. But they have been matched..
Is this correct?
Where 5 are gathered together. the square solder marks connects to the Cathode?
Where 3 are gathered together. the square solder marks connects to the Anode?
I have (on hand) 2 pcs identical 2*12v secondaries 15va toriods. Is this enough for testing purposes? I could maybe parallell them so I get 30va?
What is recommended V and va value on transformer for dcb1?
That is enough for now..
Old 7th January 2013, 09:10 AM   #2517
Salas's Avatar
Originally Posted by bambadoo View Post
Is this correct?
Vice versa.
Old 7th January 2013, 09:14 AM   #2518
Salas's Avatar
For testing purposes and your 10 Ohm setting resistors, one Tx will be enough. To parallel successfully they should be well matched. A 50VA 15+15V Tx is good in general up to medium hot rod.
Old 7th January 2013, 09:21 AM   #2519
Vice versa.
Hehe - sorry of course - At work now and my mind is elsewhere...
Old 7th January 2013, 12:46 PM   #2520
Square hole is Led's anode in this pcb as crt designated that half circle symbol over the 5 Led groups, when its the cathode in the 3 Led groups. If you put just one in reverse they will not shine, but no reason to blow a reservoir cap. In fact its the first time I hear someone blows a reservoir cap. Could it be it was reversed for polarity by accidental insertion or just very unlucky to chance on a dodgy one?
Yes it was this post I was thinking of..
Sincerely
Salas hotrodded blue DCB1 buildHide this!Advertise here!
dcb1 buffer with shunt reg. merlin2069er Swap Meet 0 3rd August 2010 05:25 PM
F2 and DCB1 parts selection - please advice! DQ Pass Labs 6 25th November 2009 03:20 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 07:40 AM
