Salas hotrodded blue DCB1 build
Old 26th November 2012, 10:38 AM   #2461
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
Is it PSU or BUFFER fault ??
Check output voltages of the PSU.
Old 26th November 2012, 10:44 AM   #2462
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by dtses View Post
thanks! is it safe to keep them above 60c? Anyway I was planning to attach them to the chassis.
Its true those diodes have a high 175C internal junction break point, but electronics do last 4 times longer each time you halve their operating temperature. So don't be much afraid for them during testing but help them when finishing the build because it is likely they are going to live in high ambient in that hot rod box. For the electrolytics, especially the big ones,they will fair best if 105C rated.
Old 26th November 2012, 10:45 AM   #2463
Salas's Avatar
What fault? He is referring to voltage drop across CCS setting resistors. Not rails voltages.
Old 26th November 2012, 12:07 PM   #2464
I was referring to POST 2449. He seems to have afaulty amplifier ??
Old 26th November 2012, 12:15 PM   #2465
R.I.P.
..............0.71 1 W/(m.K).......for Mica and .............0.6 for Kapton......or even 0.12
note the units, W/mK
The 0.71 looks like the highest Watts. That makes it the best. But you must also take account of the thickness.
Mica generally comes in thicknesses varying from 1thou (1mil= 0.001") to 6thou (6mil = 0.006")
Kapton tape in thickness varying from 1.5thou to 6thou.
Coated Kapton in thickness varying from 3thou to 9thou.
The very thinnest mica outperforms all the coated Kaptons and is just about equal to a gooped Kapton of 1.5thou if you can find any uncoated Kapton tape that thin. Uncoated Kapton will need goop on both sides. Makes it just as messy as Mica.
regards Andrew T.
Old 26th November 2012, 12:17 PM   #2466
Salas's Avatar
Ah, that was in another page. He must check his semis and everything really.
Old 26th November 2012, 07:54 PM   #2467
dtses is offline dtses
Put evrything in the case and attached the fets with metal bolts, closed the lid and let it warm up for about 40 mins. So here is what i got:
-1.87 & 1.97vdc across 3ohm R
-0.01 & 0.09 mA offset
-10.79 & 10.79 vdc output
-42c on the fets
-about 40c on the sinks (barely warm when I touch them)
-62c on the surface of poor little toroid placed out of the case
The whole case i kind of a heatsink. I didn't use any thermal paste yet. The are ventilation holes only on the top lid, so I assume need to add some to the bottom...
How more may I torture this little toroid, is it safe to put another 6R across, making it close to 1A per rail?! I do not have any spare transformers, only if I borrow 100VA 2x18vac from MyRev FE, but I'm not sure if that is a good idea and would give similar result as with a decent 2x15vac toroid.
Another question is how far could I go with these heatsinks and what toroid to buy in the end. As it should be less than 78mm in diameter according to my layout, this narrows the choise to <80va toroid or I should be looking for R-core (65w and it would suit the case) like this one. Alternatively some custom toroid, 50-55mm in height needs to be found.
Btw, sorry for probably stupid question but is it possible to connect 2 x 50va transformers in some way?! That woul solve the problem
Old 26th November 2012, 09:10 PM   #2468
dimkasta is offline dimkasta  Greece
dimkasta's Avatar
Offset you mean mV?
A photo of the case should help us see any possible solutions to your trafo real estate problem.
About the 2x18V trafo, if you decide to try it make sure that the V on the filter caps does not exceed the V rating of the caps (~25V expected for 18V secondaries)
Old 26th November 2012, 09:39 PM   #2469
dimkasta's Avatar
I finally wired everything together on the chassis. That thing ended up HEAVY!!!
First impressions with the Caddocks are very very very very very very positive
Although having everything securely screwed on that dense and heavy chunk of metal and wood might also played a part.
Imaging and separation are in a completely new level. Mids are amazingly sharp and precise. It sounds a bit shy on the mid-lows, but it is probably the fresh soldering/wiring. It will show in a few days.
With no lid on and after 2 hours the temperature on the fets is 48C which is very close to what I wanted. The heatsinks stay at about 35C. A properly vented lid should not create any additional issues. I am thinking glass or some more wenge.
What troubles me a bit is the wire spaghetti because of the pot on the front and the DPDT switch on the back for the source selection (That one is a switchcraft and is of very nice quality (a bit pricey though)). I bet that with shorter and better separated wires the results would be better... Even better with a dual mono build but... meh...
The only thing remaining for now is to properly drill the knob and install it.
Oh and do something about that damn white led which is too bright
Salas hotrodded blue DCB1 build-dim_1322-jpg
Old 26th November 2012, 10:37 PM   #2470
Salas's Avatar
@dtses
You could attempt 1A it looks like with your now sinking and measured temps. The limiting factor is your little hot transfo obviously. 2x18V forget it, the spare voltage will convert to high heat on the CCS and sink. Ebay R-Cores are a gamble. When made right its the best solution, when not, a downright failure for heating and buzzing. Feeling lucky on the one you linked? China is slow shipping lately except HK have in mind. About the using two little ones question: You can in general stack or arrange side by side 2x15V 50VA toroids (or any other type) and wire them in parallel. There are restrictions when paralleling though. Thus they should be coming from the same manufacturer and be same model having very low tolerances between them, and they should be wired with same magnetic polarity. Toroid's central screw should not touch the top lid. If it will you are for witnessing a catastrophic magnetic short. But you already have 630mA on average which is decent hot rod in the compact. Another option would be a 100VA single toroid in another box, saving you the hum field also. You decide based on discussed info.
@dimkasta
Nice.
Salas hotrodded blue DCB1 buildHide this!Advertise here!
dcb1 buffer with shunt reg. merlin2069er Swap Meet 0 3rd August 2010 05:25 PM
F2 and DCB1 parts selection - please advice! DQ Pass Labs 6 25th November 2009 03:20 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 07:40 AM
