Salas hotrodded blue DCB1 build
Old 23rd November 2012, 11:45 AM   #2431
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Nice it has been solved. Was that 550 a C type, or?
CCS resistors difference in voltage across is a matter of Vgs in different associated MOSFETS. No worries.
Old 23rd November 2012, 12:08 PM   #2432
dimkasta is offline dimkasta  Greece
dimkasta's Avatar
Package is here Niko
Party time with Caddocks today
Old 23rd November 2012, 12:17 PM   #2433
Salas's Avatar
Old 23rd November 2012, 12:55 PM   #2434
dtses is offline dtses
yes, BC550C!
last few things (I hope so) to clarify, do I need thermal paste if I use Kapton?
I'm going to add step attenuator that should be placed before the buffer as it was mentioned several hundred pages ago here However if I want to separate buffer from preamp (attenuator & buffer) is the wiring below correct in case that there always be only one source connected?
Old 23rd November 2012, 01:57 PM   #2435
Salas's Avatar
Don't know the thermal resistance of Kapton high temp tape. If its more than 1C/W that a common Silpad achieves, better avoid. Paste for Mica like films, yes. For Silpads, no.
I don't follow the above sketch easily, but in words, you should tap off from DCB1 (in) after the pot to a couple of extra outputs when needing non buffered attenuated outputs beyond the buffered attenuated normal ones you get from DCB1 (out).
Old 23rd November 2012, 02:26 PM   #2436
syklab is offline syklab  United States
Hi Salas,
Do I need to apply any thermal paste like those we use on CPU heatsink for Silpad?
Old 23rd November 2012, 02:30 PM   #2437
Salas's Avatar
If its a hot rod and you use Mica, those for CPU are best, but see they are non conductive.
For Silpad NO. Makes it worse.
Old 23rd November 2012, 02:32 PM   #2438
dimkasta's Avatar
From what I read in the description of Kapton it seems to be a heat resistant tape. It seems to block heat for example for heat wave soldering and not let it pass through.
In a heatsink you need exactly the opposite
Old 23rd November 2012, 02:43 PM   #2439
Then what should we use for white Silpad ?
Old 23rd November 2012, 02:54 PM   #2440
Salas's Avatar
Just the Silpad, no thermal paste.
Salas hotrodded blue DCB1 buildHide this!Advertise here!
dcb1 buffer with shunt reg. merlin2069er Swap Meet 0 3rd August 2010 06:25 PM
F2 and DCB1 parts selection - please advice! DQ Pass Labs 6 25th November 2009 04:20 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 08:40 AM
