| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#2401 |
Guys, do you ever find useful placing this thing on the entrance of DCB1? I'm ordering a box and might grab it to ship together.
#2402 |
diyAudio Chief Moderator
Makes sound softer when there is some aggressiveness due to mains noise. Not bad at all to test one in your box and judge in your installation.
#2403 |
Dimitris
I ve been using these in mine as a complete solution for switch, fuse box and IEC.
FN389B-6-21 Schaffner | Mouser I have no complaints so far. Not that I have done any significant tests with and without it |
#2404 |
Will try. Thanks for replies.
#2405 |
Dimitris
OK I got to finish the front and back panels today.
I routed the IEC slot with a template I made out of some 4mm plywood scraps. I also routed some of the wood where necessary to allow hardware to be properly screwed. I should have made a template for those too, but since they are not visible, I cba to do it... And if you look close enough on the top right of the knob, you will see a tiny 1,5mm hole for a led Now on the knob issue, the oil gave it a really awesome orangish tint that makes the maple really amazing. I will keep this after all. It will just require some more sanding... ![]() ![]() One more thing I have to decide is if I will use dowels to hold it together, or some inner skeleton wenge beams
#2406 |
Dimitris
Dry fitting everything to see if I forgot something. All seems ok.
![]() Tomorrow I will start drilling the plate and heatsinks. And if I have time, I will glue and screw the panels tightly. In the meantime, I have to get some more wood to make the top lid and figure out a nice layout for it to allow ventilation. |
#2407 |
Coming to shape nicely bit by bit...
#2408 |
...How come and you did not contemplate Z Foils in the signal path yet? The 220R quartet I mean. All full out DCB1 builders do that at a point.
#2409 |
Dimitris
Never thought about it to be honest. Any suggestions I should consider?
#2410 |
They can be cheaper in American vendors.
| dcb1 buffer with shunt reg. | merlin2069er | Swap Meet | 0 | 3rd August 2010 05:25 PM |
| F2 and DCB1 parts selection - please advice! | DQ | Pass Labs | 6 | 25th November 2009 03:20 PM |
| Y B Blue - how blue LED improves the CD playback | Peter Daniel | Digital Source | 176 | 25th September 2003 07:40 AM |
