Salas hotrodded blue DCB1 build
Old 4th November 2012, 11:02 PM   #2291
Erlend Sæterdal is offline Erlend Sæterdal  Denmark
Originally Posted by Salas View Post
The your choice stuff is about parts ''quality'' not values. We can't recommend pricey parts to everybody. It works without electrical differences from generic to ''Rolex''.
There are options between high CCS, low CCS, reg only, full buffer. Matched fets are the quad behind the relay.
Big diodes and big 10W 10R resistors and big heatsinks make it hotrod. Small diodes, 47/47R small resistors, mini heatsinks make it regular.
Tea had a blog I think showing the prototype constructed.
Blue DCB1 is not a kit, its a better board for a very extensively discussed project. Has its options, and its very easy to figure. All builders are happy to explain specifics.
Wonder why 10 ohm resistors did not make it hot at all ?
Old 4th November 2012, 11:18 PM   #2292
R.I.P.
Which bit do you want to get "hot"?
The 10W resistor, or the Shunt mosFET, or the CCS mosFET, or the PCB traces, or ...... ?
regards Andrew T.
Old 4th November 2012, 11:47 PM   #2293
The shunt mosfet or just something .As I remember nothing got Hot at all. It is in our club and for some reason we have not used it yet. It was intended for use with bad designed Audio Note dacs.
Old 5th November 2012, 12:15 AM   #2294
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Use 2.2R 10W resistors and it will get hot. Those MOSFETS are 0.83 RΘJC devices included to can go in amperes constant current if chosen so. Use green 2V+ leds in the triplets to aid voltage drop over the Rset as the Vgs nears the total Vf with stronger current choices. Have your K probe or laser aiming thermometer handy to check your sinks are sufficient.
Old 5th November 2012, 12:23 AM   #2295
Maybe I will try that in the New year ! We have to listen to it first to exsperience if there is need for that.
Old 5th November 2012, 12:26 AM   #2296
Salas's Avatar
Need no, diy urge yes.
Old 5th November 2012, 12:27 AM   #2297
Salas's Avatar
Those MOSFETS really pick up when run heavy, they are big VMOS like the ones you have seen in class A American amps. 10R is just stage one. If its sinked on a biggish plate or chunky sinks you won't feel it hot.
Old 5th November 2012, 05:46 AM   #2298
ma_coule is offline ma_coule  Slovenia
Originally Posted by ma_coule View Post
Hi Tea-Bag,
any boards and kits left?
Should I go to China?
Old 5th November 2012, 05:47 AM   #2299
Old 5th November 2012, 06:01 AM   #2300
Salas's Avatar
Come to Greece, I will give you one, we are near.
Salas hotrodded blue DCB1 buildHide this!Advertise here!
dcb1 buffer with shunt reg. merlin2069er Swap Meet 0 3rd August 2010 05:25 PM
F2 and DCB1 parts selection - please advice! DQ Pass Labs 6 25th November 2009 03:20 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 07:40 AM
