Salas hotrodded blue DCB1 build - Page 223 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 6th October 2012, 09:23 PM   #2221
jeff517 is offline jeff517  United States
jeff517's Avatar
I'm 99% positive I've got it all put together correctly. Like I said 99% but I always look for MY mistakes first. I'm going to replace cap and see what happens. I do remember all leds lit up the one side went dark and then my son said "Hey Dad! It's smoking!" he thinks I'm crazy for doing this as he thinks everything computer is where it's at.
I'll let you know what happens.
Old 6th October 2012, 09:28 PM   #2222
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Check the 3 Leds groups, they use the opposite shape pad to the 5 strong groups for anode or cathode. Basically follow the semi circle. Flat side is cathode, i.e. the short leg on an non clipped LED.
Old 6th October 2012, 09:33 PM   #2223
jeff517's Avatar
All as it should be. maybe bad cap? truth is stranger than fiction...
Old 6th October 2012, 09:34 PM   #2224
Salas's Avatar
But you say all lit up. Maybe a Mosfet gone instantly? Are they OK for types and pcb sides? Inspect their writing on their cases carefully, they stamp it lightly some times or use laser.
Fuse it low and try again. All Mosfets should show a bit lower than 4V between their G, S pins or there about.
Old 6th October 2012, 09:37 PM   #2225
Salas's Avatar
Don't know how bad a cap can come to blow instantly, I have heard some stories but never occured to me so dodgy. Take out a pair, the bad and its opposite side mate, run it on two cylinders to see.
Old 6th October 2012, 09:42 PM   #2226
Salas's Avatar
See also if a diode is bad as I wrote before, don't forget those. They all should show a forward drop.
Old 7th October 2012, 08:37 PM   #2227
atupi is offline atupi  Romania
Found some kind a cheap BG STD but only 220uf/16v. Would they be good for the DCB1 or i should remain stick to 100uf?
Old 7th October 2012, 08:58 PM   #2228
Salas's Avatar
Stick to 100uF. Silmic II black sleeve or Nichicon Muse KZ.
Old 10th October 2012, 12:18 PM   #2229
bulb tester in the supply for all new and modified builds using mains power.
Test each in stages. Transformer, then transformer+rectifier/s, then transformer+rectifier+smoothing cap, etc......
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 30th October 2012, 11:44 PM   #2230
dimkasta's Avatar
After a few months of having Tea-Bag's kit on the side collecting dust, I finally decided it s time to get something more than a plain pot for my system. (I really don t like the passive approach with my setup)
The parts were soldered as proposed on the thread and the guides. The leds were measured at 5,61V and 9,35V per side.
Unfortunately my DMM's mA measurement is fubar and I am a bit lazy to make any resistor/voltage based setup, so I will have to trust Tea-Bag's matching kind-of blindly (marked as 8,3x mA)...
The kit came with 10R resistors so 1st level hotrod (for now).
The fets and the diodes will be soldered after the bottom plate is drilled and the components insulated and screwed in place (here they are layed around randomly).
The bottom will be a 40cm x 40cm aluminum plate 5mm thick and with around 3cms bent on each side to allow for easier and sturdier side mounting.
The target is to get it eventually to 2nd tier or a bit more, depending on how well the aluminum plate will dissipate the heat (Any comments on how feasible is that without any extra side heatsinks?).
I am too tired to play with mains now, so I will have to do the final drilling soldering and testing tomorrow.
The test transformer will be a Hammond 2x12V @ 120VA. The hammonds run a bit on the low side of voltages also, so I will have to get a proper 15V one eventually.
dcb1 buffer with shunt reg. merlin2069er Swap Meet 0 3rd August 2010 06:25 PM
F2 and DCB1 parts selection - please advice! DQ Pass Labs 6 25th November 2009 04:20 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 08:40 AM
Copyright 1999-2017 diyAudio
