| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#2181 |
I don't have the knowledge to devise the tests required to prove the PSU is stable with input artifacts applied.
#2182 |
I am finishing my DCB1 build, and since I use will use it with several different amps(one being Aleph 5 monos), I am building it with caps on the output. In post# 295 Salas says to put 1M resisters after the caps so the caps will not be floating. Does this mean to run the caps to the ouput+ and then run the resistors from here to the output-? This is how it appears in the Marra's build photo in post# 342.
#2183 |
diyAudio Chief Moderator
Like this
#2184 |
I'm curious which 10k step attenuator to choose for the hot rod DCB1?
-4x24 Ladder Type -23 step is there any technical advantage in the Ladder? Noticed that many built their buffers with LDRs, is there a dramatic improvement over Dale step attenuator? Last edited by dtses; 5th September 2012 at 12:03 PM. |
#2185 |
The ladder is simpler and much cheaper. I wanted the purest possible sound (fewest possible components in the signal path), so I went with the LDR (buildanamp.com). I relied on the advice of the DIYaudio members who have compared both and can hear a difference.
Michael |
#2186 |
cheers Mike,
thanks for the link! I might consider LDR as well. As I've understood the 2nd one I've listed is not of a ladder type, isn't it? |
#2187 |
If I understand correctly, the Ladder style attenuator is so called because each step uses two resistors, maintaining the input impedance to the same value at every step.
#2188 |
Right, the second one is not a ladder, as it doesn't have enough resistors. It's a series type which works just like a conventional pot, only in increments.
#2189 |
Also there is a max of 2 resistors in the circuit at all times. If you do decide to go ladder and remote control is of interest, there are several board-based designs around. Most have more than 23 steps, which allows finer adjustment. A 23 step usually allows for 3dB adjustments where a ladder array can get you to 0.5dB.
Michael |
#2190 | |
| dcb1 buffer with shunt reg. | merlin2069er | Swap Meet | 0 | 3rd August 2010 05:25 PM |
| F2 and DCB1 parts selection - please advice! | DQ | Pass Labs | 6 | 25th November 2009 03:20 PM |
| Y B Blue - how blue LED improves the CD playback | Peter Daniel | Digital Source | 176 | 25th September 2003 07:40 AM |
