Salas hotrodded blue DCB1 build
Old 16th August 2012, 08:57 PM   #2131
mjock3 is offline mjock3  United States
I was going to use it in a second system, but I will certainly try it in that system. If it pans out I may even make one of those balanced dcb1's.
Old 16th August 2012, 09:01 PM   #2132
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
What pre you got in the main system?
Old 16th August 2012, 10:43 PM   #2133
Well right now I don't. But I am in need of some gain. So I am looking into what my options are. Do you have any suggestions?? Maybe diy?
Old 16th August 2012, 11:16 PM   #2134
I am hoping to do something with tubes for the preamp. And I do have some of your HV boards. I am just being a bit cautious as I don't want to put money into something that is going to degrade what I have now after spending the time and money on it.
The Salks by the way I was not prepared for. It was such a good deal I got on them. And a friend with a pair of HT2TL's so I knew I really liked Salks. I also had an opportunity to hear a few other Salks before this deal came around.
So do you have any suggestions??
Old 17th August 2012, 12:34 AM   #2135
Salas's Avatar
Your speakers are low SPL, Ncore is 20dB gain. You need XLR in & out from digital source? Start with an Aleph P1.7. Risking a balanced tube preamp diy as first step takes much experience, money, and effort.
Old 17th August 2012, 11:31 AM   #2136
Erlend Sæterdal is offline Erlend Sæterdal  Denmark
Default Raise NCore gain
It is possible to increase gain in the NCORE. Just read the manual.
Old 17th August 2012, 12:22 PM   #2137
atupi is offline atupi  Romania
Salas, if i want to adapt the power supply used in DCB1 for +/- 5V what changes i need to do ? The source used in RIAA preamp seem a bit simpler but is as effective as this one used in DCB1 ?
Sorry if i am a but offtopic but lost between your threads.
Adrian
Old 17th August 2012, 02:58 PM   #2138
BigE is offline BigE  Canada
BigE's Avatar
How about going dual mono by using two hypnotize boards, and populating only one channel of each buffer? This solves the mechanical problem of attaching a monster heat sink, although at the expense of nearly doubling the parts.
I don't think that hotrodding two boards to 600 ma will be appropriate with an 80 va toroid. 160 va would be much better.
Old 17th August 2012, 03:01 PM   #2139
pinnocchio is offline pinnocchio  Canada
pinnocchio's Avatar
Mine are at 600mA (using two for balanced) and using 100VA transfos on each. The transfos don't even get warm. 80VA ought to be more than enough
Do
PREAMPs : Bal AMB α10 + JC-80 | Bal DCB1 | Bal LDR3x | AMPs: AMB β24 | USSA3 & 5 | FO v1.4 | TGM8 | VZ Audio NS OPS | NX Amp | FC-100
DACs : TPA Buffalo II + OPC's NTD1 I/V | JLsounds | Mirand AK4490 + Discrete Output Speakers : Troels Gravesen ATS-4 | Sagwee LT V3
Old 17th August 2012, 03:02 PM   #2140
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
Adrian
Adrian, you want BiB.
http://www.diyaudio.com/forums/power...ml#post2639433
Read guide first.
Salas Boards 2018#1 On Order | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards, PS and transformers Available PM | Sony VFET CSX2 AL boards In Stock
Salas hotrodded blue DCB1 buildHide this!Advertise here!
dcb1 buffer with shunt reg. merlin2069er Swap Meet 0 3rd August 2010 05:25 PM
F2 and DCB1 parts selection - please advice! DQ Pass Labs 6 25th November 2009 03:20 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 07:40 AM
