Salas hotrodded blue DCB1 build
Old 15th August 2012, 11:10 PM   #2111
suburra is offline suburra  Italy
No...was new caps
But it's possible i'm attached my solder station into a power strip without ground connection
Can a static fry the Mosfets?
Old 15th August 2012, 11:12 PM   #2112
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Sure.
Old 15th August 2012, 11:19 PM   #2113
I did not think were so delicate...
Hope tomorrow or friday to have new mosfet
thank you very much for help me
Marco
Old 16th August 2012, 06:53 PM   #2114
mjock3 is offline mjock3  United States
Almost done, but want to fuse the line before plugging in. What size should I use?
Thanks,
Mark
Old 16th August 2012, 07:00 PM   #2115
Salas's Avatar
What your trafo's primary notes, or tell us more about your trafo.
Old 16th August 2012, 07:07 PM   #2116
I am using an Antek AS-1215
Old 16th August 2012, 07:09 PM   #2117
http://www.antekinc.com/pdf/AS-1215.pdf
Old 16th August 2012, 07:12 PM   #2118
Salas's Avatar
500mA
Old 16th August 2012, 07:14 PM   #2119
Thanks Salas.
Now how did you figure that out? I'd like try to remember for the future.
Mark
Old 16th August 2012, 07:16 PM   #2120
Salas's Avatar
*Slow blow. I gave you a conservative rating, if it draws too much at start up when building magnetic field and blows it go up empirically. Should not need more than 1Amp fuse in any case.
Salas hotrodded blue DCB1 buildHide this!Advertise here!
dcb1 buffer with shunt reg. merlin2069er Swap Meet 0 3rd August 2010 05:25 PM
F2 and DCB1 parts selection - please advice! DQ Pass Labs 6 25th November 2009 03:20 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 07:40 AM
