Salas hotrodded blue DCB1 build
Old 15th August 2012, 02:41 PM   #2101
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by atupi View Post
I want to install my DCB1 buffer into a metal case. It's ok to connect the case to the GND of pcb ? I'm using isolated RCA connectors.
Its OK.
Old 15th August 2012, 02:48 PM   #2102
Salas's Avatar
Originally Posted by boywonder View Post
My DCB1 is working fine, but I have a few questions.....
I'm running 10 ohm R's (200ma config) with two separate 60VA 12V single secondary transformers (so 120VA total). My DC output voltages are +10.04 and -10.11 and the unloaded transformer voltages are about 13.2VDC. I understand that for most of the various hot rod configs at least 15VDC/50VA is recommended. How do I test/verify that I have enough voltage headroom with my transformers? Should I measure the DC output voltage stability with a 5K or 10K load on the outputs at full input signal?
I'm also measuring 2V across the 10R on the IRFP240 side and 1.75V across the 10R on the 9240 side, so 200ma and 175ma. I understand this is the quiescent current for the shunt part of the PS.
Is it normal to have 25ma different between the + and - sides? I am assuming that it is, and is probably no big deal.
VAC on secondaries you probably mean. Measure DC across DCB1's filter capacitors. If it is >VDC rails by 5V even in your lowest mains expected, then you are OK. Signal demand is a minute portion, the PSU setting is the constant current hog.
Its normal to have differences in non Vgs matched MOSFETs especially when opposite sexes like those in opposite rails here that have more Vgs differences than in same sex batch spread. That leads to some (inconsequential) quiescent dif. You may trim that by the setting resistors but to no perceptible gain.
Old 15th August 2012, 03:46 PM   #2103
boywonder is offline boywonder  United States
boywonder's Avatar
Yes Salas VAC on the unloaded transformer secondaries.....sorry.
My rectified DC voltage at the second 4700uf PS cap is 17.85VDC.
Thanks!
Old 15th August 2012, 04:23 PM   #2104
Salas's Avatar
More than adequate Vout to Vin margin. No problems at all.
Old 15th August 2012, 10:23 PM   #2105
suburra is offline suburra  Italy
Originally Posted by Salas View Post
See if they show Vgs.
Checked Vgs: 0,00 V on either Mosfets...
Marco
Old 15th August 2012, 10:47 PM   #2106
Salas's Avatar
The output ones? Or all 4?
Old 15th August 2012, 10:55 PM   #2107
Just the output pair
Old 15th August 2012, 11:00 PM   #2108
Salas's Avatar
Do you have spares to exchange?
Old 15th August 2012, 11:02 PM   #2109
Ordered some days ago...
i'm waiting RS delivery
Old 15th August 2012, 11:06 PM   #2110
Salas's Avatar
Lets see if they got zapped during soldering rework then. Were the new caps charged by any chance?
Salas hotrodded blue DCB1 buildHide this!Advertise here!
dcb1 buffer with shunt reg. merlin2069er Swap Meet 0 3rd August 2010 05:25 PM
F2 and DCB1 parts selection - please advice! DQ Pass Labs 6 25th November 2009 03:20 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 07:40 AM
