| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#2091 |
diyAudio Chief Moderator
There is no reason losing the Vref for just tasting termination capacitors. Some mishap must have occurred during ''operations''. See if the JFETs at the 5 LEDS tails are intact also. Is your iron showing ~0 Ohm from tip to its mains earth prong? Is it static safe in other words? Check for live Vbe, Vgs, everything semi.
#2092 |
Salas
My solder station it's "static safe" I'll check all the semiconductors and report many thanks Marco ps the 2 mosfets near 100uF capacitors, remain cool by turning on the unit... |
#2093 |
See if they show Vgs.
#2094 |
OK folks, I'm ready to put some power to this thing. I have an ANTEK 50Va by 12v x 2 torroidal transformer. 2 red, 2 black and 1 purple wires on 120v side. And 2 green and 2 blue wires on 12v side. Do I wire mains(120 side) in parallel, and same on 12v side?
Too many wires and I would really like to not toast this board up.Suggestions? Last edited by jeff517; 14th August 2012 at 02:06 AM. |
#2095 |
#2096 |
Secondaries to DCB1's transformer connector marked AC IN as shown. Primaries in parallel for USA mains. Purple magnetic shield wire bolts with the mains ground wire to chassis.
#2097 |
and use a bulb tester for the power up.
#2098 |
Thank you all for your patience and help.
#2099 |
I want to install my DCB1 buffer into a metal case. It's ok to connect the case to the GND of pcb ? I'm using isolated RCA connectors.
#2100 |
My DCB1 is working fine, but I have a few questions.....
I'm running 10 ohm R's (200ma config) with two separate 60VA 12V single secondary transformers (so 120VA total). My DC output voltages are +10.04 and -10.11 and the unloaded transformer voltages are about 13.2VDC. I understand that for most of the various hot rod configs at least 15VDC/50VA is recommended. How do I test/verify that I have enough voltage headroom with my transformers? Should I measure the DC output voltage stability with a 5K or 10K load on the outputs at full input signal? I'm also measuring 2V across the 10R on the IRFP240 side and 1.75V across the 10R on the 9240 side, so 200ma and 175ma. I understand this is the quiescent current for the shunt part of the PS. Is it normal to have 25ma different between the + and - sides? I am assuming that it is, and is probably no big deal. |
| dcb1 buffer with shunt reg. | merlin2069er | Swap Meet | 0 | 3rd August 2010 05:25 PM |
| F2 and DCB1 parts selection - please advice! | DQ | Pass Labs | 6 | 25th November 2009 03:20 PM |
| Y B Blue - how blue LED improves the CD playback | Peter Daniel | Digital Source | 176 | 25th September 2003 07:40 AM |
