Go Back   Home > Forums > Source & Line > Analog Line Level
Old 2nd August 2012, 04:25 PM   #2071
boywonder's Avatar
got it, thanks......assuming you mean swap the inner/outer positions for each pair.
Old 2nd August 2012, 04:36 PM   #2072
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Yep.
Old 4th August 2012, 02:58 PM   #2073
mjock3 is offline mjock3  United States
Default heat sink
Would a heat sink rated at 1.3 C/W 11mmx61mmx35mm be enough on each side for a 600ma hot rod?
Old 4th August 2012, 03:03 PM   #2074
Just DIY!
pinnocchio's Avatar
Send a message via MSN to pinnocchio
I think you will see fire and explosions of the mosfets
PREAMPs : AMB α10 + JC-80 clone | Balanced DCB1 | AMPs: AMB β24 | Aleph 5 | Symef | Hiraga | ML-2 | Fetzilla | Telos 390 Clone
DACs : TPA Buffalo II + NTD1 I/V | TPA OPUS + IVY III Speakers : Jim Holtz Statements | Astasia SD | Tubasson Mark 2
Old 4th August 2012, 03:04 PM   #2075
Salas's Avatar
He probably meant cm.
Old 4th August 2012, 03:05 PM   #2076
How do I go about figuring out what I need. I don't understand what to look for.
Old 4th August 2012, 03:06 PM   #2077
I meant 116mmx61x35
Old 4th August 2012, 03:08 PM   #2078
Salas's Avatar
W/C is the key. 1.3W/C when receiving 12W heat per rail assuming 10V across each Mosfet @ 0.6A they gonna rise 15.6C above box's ambient.
Old 4th August 2012, 03:10 PM   #2079
Salas's Avatar
If your box is roomy, ventilated, even with 40C inside you are safe at under 60C on the fins.
Old 4th August 2012, 03:21 PM   #2080
Thanks Salas
dcb1 buffer with shunt reg. merlin2069er Swap Meet 0 3rd August 2010 05:25 PM
F2 and DCB1 parts selection - please advice! DQ Pass Labs 6 25th November 2009 03:20 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 07:40 AM
Copyright ©1999-2013 diyAudio
