Now your build has the standard ~10.000uF total per side of high ripple current capacitors?
If yes they will hold their own to much more for spec. Subjectively big transformer and more capacitance some may like or not, but technically the now components are very capable.
Yes, it has 9400 uF per polarity.
I measured THD+Noise of the DCB1 using audiodiffmaker. Here is how to do it with an ADC for recording:
Record Sample 1 direct from CD player.
Record Sample 2 from CD player via DCB1 at full volume.
Use audiodiffmaker to create a difference file, "Sample 1 - Sample 2".
Import the difference file into audacity and analyze spectrum.
The spectrum plot of the difference (THD and noise) was -84 dB or 0.0063% at full volume.
I wonder if a larger power supply with greater voltage drop would have a measurable difference?
Just finished fine; sounds great!
High-output phono stage: Hypnotoad HTMCPS
Low-output phono stage: Hypnotoad AD797
Attenuator: Goldpoint Mini-V
Remote control module: Bent Audio Remote Volume System
Transformer / shield: Antek
40 mm billet AL knobs: eBay
12 VDC remote power supply: eBay
Input selector: eBay
Misc parts: Parts Express
Case: Homebrew (left-over 8/4ths walnut stock; perforated aluminum baking pan; aluminum stock from Lowe's)
Build thread here.
Build thread here.
Yes; solid state on the woofers and tubes on the horns. If you insist!
I made the stereo and LP cabinets, speaker stands and amp plinths out of walnut or (for the cabinets) walnut veneered plywood.
Made Some Walnut LP and Stereo Cabinets - AudioKarma.org Home Audio Stereo Discussion Forums
VTA Dynaco MK3s ... in Walnut - AudioKarma.org Home Audio Stereo Discussion Forums
The preamp is now where the Adcom was in the top right.
- Analog Line Level
- Salas hotrodded blue DCB1 build
