Salas hotrodded blue DCB1 build - Page 19 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 29th August 2010, 01:20 AM   #181
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Correctly oriented. That horizontal line on the relay's case is tell tale and it is depicted on the board too. Did you jumper the ''Note'' resistor position too? You got a 12V one. Are those round diodes Philips?
Leds OK too. You will need proper sinking with 10R setting.
Old 29th August 2010, 02:07 AM   #182
Hi Salas,
Thanks for the confirmation. Yes, the diodes are phillips. I need to jumper where it says note and leave the 600r location empty, correct?
Also, you recommended that I go with 8.2r due to my TX being 21v and also cutting the tracks and attach the PSU caps with 39r. These have yet to be done.
Old 29th August 2010, 02:51 AM   #183
Salas's Avatar
Correct.
Old 29th August 2010, 03:00 AM   #184
Salas's Avatar
Creating a CRC by putting 39R 5W in between filter caps. If you sink the Mosfets well (cheapest & easiest way is on thick metallic floor), with 8R2 you will drop better on those 39R. Creating a pre filter, running in good hotrod territory and utilizing your existing overspec Tx safely. Not bad.
Old 29th August 2010, 08:39 AM   #185
dvb projekt's Avatar
Originally Posted by nycavsr2000 View Post
Beautiful work!
Are your 220K resistors also TX2575's? Do they make single 220K resistors or are they a series daisy chain of several resistors?
See here to understand what I mean.
Anand.
Ups... Youre correct about the 220K position. I have ordered two TX2352 there.
Originally Posted by LucasAdamson View Post
That's some extremely extravagant components you're using there.
Is there a real advantage to using "audio signal path grade" resistors such as the PRPs for the shunt reg and delay? I have used bog-standard .6W metal film Vishay Sfernice for mine and Tea-Bag's supplied PRPs in the audio path. I will post pictures when I've finished the delay.
Also, what milli-ampage are you pulling with those Mills 22Rs? Was there a particular reason you chose not to stick with the 10R Dales?
Great pictures. Many thanks for that!
Because (thank god) we dont have to look at any cost calculation i use the PRPs in the standard positions.
The 22R Mills set the shunt to around 92mA. I like the non inductive, non magnetic style of the MRA5.
Besides that they are really small for a 5W if you compare them to e.g. the Kiwame.
Best regards,
Oliver
Reference TDA1541A DAC project PCBs / Tube-I-zator PCB
Stock status in my Blog
Old 29th August 2010, 09:34 AM   #186
LucasAdamson's Avatar
Best regards,
Oliver
Warm Rod! Not as catchy, but I like it.
Lucas
Old 29th August 2010, 11:10 AM   #187
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
speaking of relay's it looks like dvb-projects relay is mounted backwards.
Might want to double check.
Salas Boards GB 2016#3 Closed SHIPPED Now | Hot-Rod DCB1 boards and kits In Stock, PM| M2CBoards and transformers In stock
Old 29th August 2010, 11:39 AM   #188
Here is the corrected overview
Thanks Tea
Old 29th August 2010, 12:08 PM   #189
hates ground loops
Rodeodave's Avatar
Nicely populated board! I'm so looking forward to get mine, should arrive next Week.
Where can I find the Takamisawa A12W-K relay? Seems to be obsolete...
Gravity - Making the G since 13.7 billion B.C.
Old 29th August 2010, 12:22 PM   #190
I ordered them at Hifituning 24.
dcb1 buffer with shunt reg. merlin2069er Swap Meet 0 3rd August 2010 06:25 PM
F2 and DCB1 parts selection - please advice! DQ Pass Labs 6 25th November 2009 04:20 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 08:40 AM
Copyright 1999-2017 diyAudio
