| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#1851 | |
#1852 | |
#1853 |
If you are going to set and forget then that is fine.
Just imagine an infinite gain amplifier (an ideal op-amp) with a dodgy connection (a variable resistor) in its feedback loop. As you adjust the pot. the gain can vary from (say) 1 to (say) 1000000. The slightest crackle will be immediately amplified over 1 million times. Personally I would use the pot to ascertain the fixed resistor that you need. Last edited by KatieandDad; 14th April 2012 at 01:14 PM. |
#1854 | |
#1855 |
Just finish building the DCB1
Neg rail measure 10.06VDC Voltage drop across the 10R is 1.909V Pos rail measure 10.3 VDV Voltage drop across the 10R is 2.028V DC offset Left 2.0mV Right 1.6mV AC input 16.52 and 16.54VAC The relay kicks in 15 sec after power on. Next thing is to connect a 20k volume and start the listen test. Last edited by syklab; 15th April 2012 at 08:25 AM. |
#1856 |
Schubert,
I would still build fixed gain stages and vary the volume as opposed to the gain with trimpots at the inputs. |
#1857 |
#1858 |
I'm surprised you need a heatsink on the LM7812 ????
#1859 |
diyAudio Chief Moderator
Most sink it, there is enough drop over it with 2X15 Tx. Not essential, but helps reliability.
Nice build syklab, congrats. |
#1860 |
If you are using 5V relays without current saver and a mesmerize then a sink may be necessary.
But a Hypnotize with a 12V relay should not require a sink on the regulator. If you add a current saver then both Hyp & Mes should not need a sink for 12V relays. I have a Mes running day and night on 15+15Vac, with two 12V relays pulled in, a current saver active and the reg without sink, is running cooler than my finger, i.e. Tc<36°C Last edited by AndrewT; 15th April 2012 at 12:08 PM. |
| dcb1 buffer with shunt reg. | merlin2069er | Swap Meet | 0 | 3rd August 2010 05:25 PM |
| F2 and DCB1 parts selection - please advice! | DQ | Pass Labs | 6 | 25th November 2009 03:20 PM |
| Y B Blue - how blue LED improves the CD playback | Peter Daniel | Digital Source | 176 | 25th September 2003 07:40 AM |
