Salas hotrodded blue DCB1 build
Old 18th March 2012, 03:55 PM   #1741
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by Siberia View Post
Tx secondaries: 16.60V; +16.72
-1.6; +0.9 is Dc offset on output.
Sorry, if it's counterintuive.
So you got about 21VDC in on the filter capacitors?
Old 18th March 2012, 03:58 PM   #1742
rikkert1978 is offline rikkert1978  Netherlands
Salas, my voltage before rectification is 12.28V, and after the diode bridge the voltage is 13.50V DC
Old 18th March 2012, 04:13 PM   #1743
Siberia is offline Siberia  Lithuania
Siberia's Avatar
I've got 20VDC in measured a minute ago under first capacitors.
Old 18th March 2012, 04:33 PM   #1744
Salas's Avatar
Better go for a 15+15VAC transformer when convinient.
Old 18th March 2012, 04:34 PM   #1745
Salas's Avatar
Plenty.
Old 18th March 2012, 05:21 PM   #1746
syklab is offline syklab  United States
Hi Salas,
Does the made/brand of PS cap make much difference in the hotrodded blue DCB1 design ? Doesn't the shunt reg shielded the buffer from ESR and ripples? I am think how expensive Caps like MUNDORF M-Lytic AG vs reasonable cap like Pana or CDE will make much different here? Any comment?
Old 18th March 2012, 06:00 PM   #1747
Salas's Avatar
In my experiments the CCS damped down the discretion between capacitors quality significantly than perceivable in raw supplies. Their impedance can still interfere to an extent though. Enough members maintain they can still subjectively pick several capacitor models out in their DCB1 builds. I would certainly advise a renowned good LowESR industrial capacitor like Panasonic or Nichicon for all the known reasons as a minimum.
Old 18th March 2012, 07:12 PM   #1748
Siberia's Avatar
Brought home borrowed from the neighbour AV receiver, same sound. This time it should be speaker related then.
Old 18th March 2012, 07:16 PM   #1749
Salas's Avatar
Only the receiver no other line stage in the chain was the test? Polarity in speakers? Did some rewiring and could be out of phase between boxes?
Old 18th March 2012, 07:30 PM   #1750
Siberia's Avatar
Cd to receiver to Speakers. Crappy receiver, but I think it showed the same character of total lack of slam. I don't remember doing any rewiring, except changing a pair of rcas on the buffer, which seems to me, was wired in a same way as before
I've checked phasing with HI Fi news test LP. Sounds allright. It's uber weird that both speakers are showing same impotence.
Salas hotrodded blue DCB1 buildHide this!Advertise here!
dcb1 buffer with shunt reg. merlin2069er Swap Meet 0 3rd August 2010 05:25 PM
F2 and DCB1 parts selection - please advice! DQ Pass Labs 6 25th November 2009 03:20 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 07:40 AM
