Salas hotrodded blue DCB1 build
Old 17th March 2012, 11:56 PM   #1731
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
Originally Posted by Siberia View Post
ClaveFremen, do you mean current setting resistors?
No, the two 220K and 1M, see attachment.
Dario
ClaveFremen "Bailando Salsa en el Sietch" - For My_Ref FE 12th GB extra boards PM me.
Old 18th March 2012, 08:37 AM   #1732
Siberia is offline Siberia  Lithuania
Siberia's Avatar
Dario, I've tried carbon films and other resistors in those and all critical positions previously. You are right, carbon films sounded bolder. But I prefer "nakeds" for their uber transparency. My problem is on bigger scale than mere tonality...
I wonder could it be heard on the file I have attached?
Salas, I've just followed your advice. Signal wires straight to pcb under it. Same sound.
I wonder also if could it be an amp related problem. For example bad amp rca connection?
Old 18th March 2012, 12:14 PM   #1733
Siberia's Avatar
If I had to describe what sound I'm getting, I would say it's all perfect except that somebody turned down low region knob on invisible eq.
Old 18th March 2012, 01:09 PM   #1734
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Weird stuff. Since its about anemic low region you are right to suspect possible power stage related issues also. A DC line stage why to periodically cut on bass if all healthy its beyond me. You need some tech tests and related equipment data so we can really say for that system as a whole. Or some luck with trial and error on connections and parts.
Old 18th March 2012, 01:13 PM   #1735
R.I.P.
VACin -16.60; +16.72
DCout -1.6; +0.9
I don't understand these measurements.
regards Andrew T.
Old 18th March 2012, 01:18 PM   #1736
qusp is offline qusp  Australia
qusp's Avatar
I presume thats supply voltage for the rails and DC offset (signal) at the output, not exactly the most intuitive way to write it
Old 18th March 2012, 01:40 PM   #1737
Siberia's Avatar
Tx secondaries: 16.60V; +16.72
-1.6; +0.9 is Dc offset on output.
Sorry, if it's counterintuive.
Old 18th March 2012, 03:14 PM   #1738
Siberia's Avatar
On my suspicion list one power amp rca which feels to have a looser connection then the other. I can tighten the plugs to grip well, but I wonder could it create the problem where "the nose" of connector it's not touching properly the conductor inside the socket?
Old 18th March 2012, 03:32 PM   #1739
rikkert1978 is offline rikkert1978  Netherlands
I finaly managed to complete my Tea-bag Kit Dcb1 build.
The kit was very easy to use, and everything seems to work also!
I do have one measurement that is kinda well... Weird.
My Vout+ and Vout - are almost the same. 9.95V and 9.94V. What I read in the manual the Vout + should be higher then Vout- ? Is this bad?
The rest of the measurements:
Voltage drop on the power resistors: 1.764V and 1.861V
The output: Right 1.6mV dc
The output: Left 1.8mV dc
Led string -9.31V and +9.32V
I am using btw a 12v transformer, (for testing) would a 15 volt one be preferred?
Old 18th March 2012, 03:54 PM   #1740
Salas's Avatar
In Hypnotize both rails tracking close is the right thing. In Mezmerize a bit apart is the right thing. So yours is OK. To tell if your OK with your Tx on your mains, give us the DC in value. You can measure it under one of the big filter capacitors.
Salas hotrodded blue DCB1 buildHide this!Advertise here!
dcb1 buffer with shunt reg. merlin2069er Swap Meet 0 3rd August 2010 05:25 PM
F2 and DCB1 parts selection - please advice! DQ Pass Labs 6 25th November 2009 03:20 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 07:40 AM
