Salas hotrodded blue DCB1 build
Old 16th March 2012, 10:23 AM   #1721
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
As long as you got no buzz from a transformer field over the signal wires, do as you please.
Old 16th March 2012, 06:04 PM   #1722
pinnocchio is offline pinnocchio  Canada
pinnocchio's Avatar
Originally Posted by ClaveFremen View Post
I've a component selection very similar to yours, try those caps...
Sadly no, too much reverbs.
Maybe Silmic first version (ROS)
Why not use the Mundorf M-Lytic Bi-polar? Those are really good and have low ESR
Do
PREAMPs : Bal AMB α10 + JC-80 | Bal DCB1 | Bal LDR3x | AMPs: AMB β24 | USSA3 & 5 | FO v1.4 | TGM8 | VZ Audio NS OPS | NX Amp | FC-100
DACs : TPA Buffalo II + OPC's NTD1 I/V | JLsounds | Mirand AK4490 + Discrete Output Speakers : Troels Gravesen ATS-4 | Sagwee LT V3
Old 17th March 2012, 01:50 PM   #1723
Siberia is offline Siberia  Lithuania
Siberia's Avatar
Wired my Tx directly to dcb1. No luck getting better results.
Old 17th March 2012, 02:01 PM   #1724
Salas's Avatar
Is there anything wrong periodically with your mains quality maybe? So your system comes and goes over a few weeks?
Old 17th March 2012, 02:15 PM   #1725
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
Siberia - maybe a few very good result ion Jpegs would help look for any nasties.
Is there a cap across the AC, like .0033 to 0.1uf X or Y rated?
Some Salas Boards In stock, PM | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards PM for sign up | Sony VFET CSX2 AL boards Shipped | Vishay/Harris MOSFETs Click Here to Sign Up!
Old 17th March 2012, 02:25 PM   #1726
Salas's Avatar
Should check the mains don't go south and the Vin - Vout margin drops too much is one thing.
Old 17th March 2012, 04:09 PM   #1727
Siberia's Avatar
Those comes and goes always had a reason that I or we have discovered eventually. Bad grounding, badly soldered wire, etc... Mains quality never played a role on it.
How do I check the "going south" thing?
These are most recent measurements:
VDC -10.30; + 10.24
VACin -16.60; +16.72
DCout -1.6; +0.9
Here are some pictures.
http://wtrns.fr/BroYUZKEF8JCGU
I could additionaly make every angle you ask.
Old 17th March 2012, 04:41 PM   #1728
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
Originally Posted by Siberia View Post
I can't get rid of the feeling that something is wrong with my DCB1. It seems I've been here before: lack of articulation in rhythm, weak slam and bass. It's almost like somebody would play the drums with cotton buds.
Do you have different shunt resistors to try?
While those naked Vishays are the best for direct signal path I don't think they're as good for shunt... you need something that sounds bolder like PRPs or carbon films IMHO.
Dario
ClaveFremen "Bailando Salsa en el Sietch" - My_Ref FE 12th GB is open
Old 17th March 2012, 05:00 PM   #1729
Siberia's Avatar
ClaveFremen, do you mean current setting resistors?
Old 17th March 2012, 11:11 PM   #1730
Salas's Avatar
VDC -10.30; + 10.24
DCout -1.6; +0.9
The way you checked is OK. Shows your mains are high enough to give margin. Regarding the pictures, maybe its better you solder the in/out wiring directly under the PCB on the connectors pads? Since you say it was always a contacts or good grounding thing, maybe worth a try.
Salas hotrodded blue DCB1 buildHide this!Advertise here!
dcb1 buffer with shunt reg. merlin2069er Swap Meet 0 3rd August 2010 05:25 PM
F2 and DCB1 parts selection - please advice! DQ Pass Labs 6 25th November 2009 03:20 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 07:40 AM
