Salas hotrodded blue DCB1 build
Old 2nd March 2012, 07:23 AM   #1691
oneplustwo is offline oneplustwo  United States
oneplustwo's Avatar
Yes, that's right! Haven't plugged it in yet... but perhaps a good idea before I get much further.
Old 2nd March 2012, 07:26 AM   #1692
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
First all leds should light up. At the regulator +/- outputs to ground, there is an easy probing place reserved for connector if used as solo PSU, see they track near at around 10V ballpark. And DC offset to be under 5mV at each audio output.
Old 2nd March 2012, 07:31 AM   #1693
oneplustwo's Avatar
Ok... if the voltage is off, I know I need to adjust the LEDs. If the offset is off, then what do I do?
Old 2nd March 2012, 07:34 AM   #1694
Salas's Avatar
See if all is well first , in case you report not, you will not walk alone.
Old 2nd March 2012, 08:13 AM   #1695
oneplustwo's Avatar
It's late, but I couldn't bear the suspense so I plugged her in.
10.51 and 10.50 volts with DC offset about 1.4 mV on both sides. Seems to be just about right! Those red LEDs are very... red. Reminds me of a fire truck!
I'm a bit torn about whether or not to install a pot. I have a LCDuino that I've built but have yet to case that I was going to use as a stand alone attenuator. But having a pot for the DCB1 as well seems like a good idea just in case. I think I have a couple Alps pots lying around. But I think they're 50K. If I remember correctly, the DCB1 would be better off with 20K-ish?
Old 2nd March 2012, 08:40 AM   #1696
Salas's Avatar
Correct, up to 20kish is best.
Old 2nd March 2012, 03:58 PM   #1697
oneplustwo's Avatar
Is it normal for the LEDs to not all be the same brightness? I didn't think anything of it since the voltage measurements were fine but wanted to double check.
Also, can the buffer be used as a headphone amp?
(Apologies if these are noobie questions... still continuing to learn!)
Old 2nd March 2012, 04:12 PM   #1698
Salas's Avatar
Yes its normal bcs of the differences in the unsorted JFETs that are driving them, and for the groups of 3 to generally have more current available shining a bit more than the groups of 5 due to there is more voltage available to their JFETs giving them more IDSS.
No, it has ~270R output impedance, even 600 Ohm headphones would need 60R output impedance for good dynamics, and more current available from bias. Not to mention the lack of gain for the inefficient ones.
Old 5th March 2012, 04:05 PM   #1699
TheShaman is offline TheShaman  Europe
Will a 30VA, 2x15AC R-Core be able to handle 600mA HotRod?
Got some nice 3.3R Mills from T-B I'd like to use.
Alternatively I can go for 5R (Vishay) resistors and keep Mills for a BiB or something.
I'm going to use Stealth II rectifiers (I have both 600V, 4A and 600V, 8A parts available). I suppose these won't need any heatsinking?
"You have a hierarchy: a mathematician, a physicist (which is a failed mathematician), and an engineer (which is a failed physicist)." - Andrew Jones
Old 5th March 2012, 05:01 PM   #1700
R.I.P.
30VA 2*15Vac has a maximum continuous AC current of 1Aac
This transformer feeding a capacitor input filter will be able to supply a maximum continuous 500mAdc to each polarity.
At this output it will run hot.
I recommend you take ~250mAdc from each winding as the maximum cool running output.
regards Andrew T.
Salas hotrodded blue DCB1 buildHide this!Advertise here!
dcb1 buffer with shunt reg. merlin2069er Swap Meet 0 3rd August 2010 05:25 PM
F2 and DCB1 parts selection - please advice! DQ Pass Labs 6 25th November 2009 03:20 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 07:40 AM
