Salas hotrodded blue DCB1 build Salas hotrodded blue DCB1 build - Page 17 - diyAudio
Old 28th August 2010, 10:45 AM   #161
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by m3744 View Post
Hi salas:
use +/- 20V DCin not too high voltage input?, because dcb1 just use +/- 10v DCin
mikeliu
Its better, although it will still regulate with lower difference.
Hi salas:
so we choose +/- 15V AC output trafo right?
Right.
Old 28th August 2010, 10:54 AM   #162
LucasAdamson is offline LucasAdamson  United Kingdom
LucasAdamson's Avatar
Hi salas:
Yes, use a 15-0-15 transformer if possible for 10V DC
Lucas
Old 28th August 2010, 05:54 PM   #163
dvb projekt is offline dvb projekt  Germany
dvb projekt's Avatar
Default 1st power up
I am still waiting to the Texas Components TX2575 resistors, but the rest is ready to show
The other resistors are PRP9372 and the four 470R at the gates are Takman REX carbon film.
Because im also waiting to a special made shielded transformer, i use one of my 12V secondaries from my DAC project transformer for the 1st power up.
Everything works perfect!
Reference TDA1541A DAC project PCBs / Tube-I-zator PCB
Stock status in my Blog
Old 28th August 2010, 06:09 PM   #164
Salas's Avatar
Nice big informative pictures. Is the heat on the small sinks comfortable with 22R CCS setting resistors? V+/V- OUT you hit close together?
Old 28th August 2010, 06:28 PM   #165
The heatsinks are perfect. With only one 12VAC input i have +10,09 VDC and a -10,16 VDC at the outputs.
Old 28th August 2010, 06:39 PM   #166
Salas's Avatar
Looks in good order. Till listening then.
Old 28th August 2010, 06:56 PM   #167
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
The first pic will be really helpful for some. Thanks for posting.
Salas Boards GB 2017#1 SHIPPED | GB 2017 #2 Click Here to Sign Up! | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards In Stock
Old 28th August 2010, 07:40 PM   #168
Thank you both and crt for this project!
Old 28th August 2010, 07:51 PM   #169
nycavsr2000 is offline nycavsr2000  United States
Beautiful work!
Are your 220K resistors also TX2575's? Do they make single 220K resistors or are they a series daisy chain of several resistors?
See here to understand what I mean.
Anand.
Old 28th August 2010, 07:52 PM   #170
That's some extremely extravagant components you're using there.
Is there a real advantage to using "audio signal path grade" resistors such as the PRPs for the shunt reg and delay? I have used bog-standard .6W metal film Vishay Sfernice for mine and Tea-Bag's supplied PRPs in the audio path. I will post pictures when I've finished the delay.
Also, what milli-ampage are you pulling with those Mills 22Rs? Was there a particular reason you chose not to stick with the 10R Dales?
Great pictures. Many thanks for that!
Lucas
Salas hotrodded blue DCB1 buildHide this!Advertise here!
dcb1 buffer with shunt reg. merlin2069er Swap Meet 0 3rd August 2010 05:25 PM
F2 and DCB1 parts selection - please advice! DQ Pass Labs 6 25th November 2009 03:20 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 07:40 AM
Copyright ©1999-2017 diyAudio
