Salas hotrodded blue DCB1 build - Page 165 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 15th February 2012, 07:32 PM   #1641
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
I concur. Get low ppm Caddock IMO, or PRP 9372 TC50
More resistance @ tx instruments, more costs.
Salas Boards GB 2016#3 Closed SHIPPED Now | Hot-Rod DCB1 boards and kits In Stock, PM| M2CBoards and transformers In stock
Old 15th February 2012, 07:37 PM   #1642
ggetzoff's Avatar
I found the BOM
Airline Pilot-If it's not Boeing I'm not going.
"Brain as big as a planet..." {sic} Nelson Pass
Old 18th February 2012, 12:02 AM   #1643
palmito is offline palmito  United States
palmito's Avatar
Hi. I replaced all my signal path PRP resistors with Caddock 132's in the 1m
position, TF020's in the 220k position and TX2575 in the 220R position. The
sound is a lot smoother and detailed and the imaging improved a bit. As Dart
Vader used to say: "most impressive"!
Currently I have Nichicon FX 4700uf and KZ 100uf capacitors installed. Will
replacing any of these with "better" improve the sound much? I thought of
replacing the 4700uf's with Nichicon KZ Gold or Mundorf MLytic AGs? The Nichicon's
arent too expensive, but the Mundorfs are.
Would it be worthwhile to replace the KZ's with Elna Cerafines?
Old 18th February 2012, 01:41 AM   #1644
Reality first!
ClaveFremen's Avatar
Originally Posted by palmito View Post
Currently I have Nichicon FX 4700uf and KZ 100uf capacitors installed. Will replacing any of these with "better" improve the sound much? I thought of replacing the 4700uf's with Nichicon KZ Gold or Mundorf MLytic AGs? The Nichicon's arent too expensive, but the Mundorfs are.
Mundorfs are simply the best caps you can use there but if they're too costly don't worry much about it...
IMHO yes but the best thing you can do is to try...Cerafines have reasonable cost.
Dario
ClaveFremen "Bailando Salsa en el Sietch" - My_Ref Fremen Edition Group Buy 10th Run.
Old 18th February 2012, 12:28 PM   #1645
Tea-Bag's Avatar
Did you up the bias beyond 200ma? That brought imaging up substaintially in my setup, which looks a lot like yours now. Some day I will go for the Mundorf's - if for nothing more than to express what I think of them for the masses.
The 100UF KZ vs the ELNA's is a good one. slightly different tonal charachter. Elna smoother, and Muse sharper. Get both and solder in just the leads a bit, and try them out. Of course the Elna's certainly like a lot of back in time so consider that. Leave it running for a few weeks.
Enjoy!!!
Old 18th February 2012, 02:28 PM   #1646
evanc is offline evanc  United States
Location: New Jersey. About 1 hour from NYC and 1 min. from the beach
Here's my DCB1. Totally from the parts sent by Tea-Bag. Nice complete parts kit. my first impression is very good. I'll listen a while and see how things develop.
Evan
http://www.evancotler.com
Old 18th February 2012, 02:29 PM   #1647
And the whole thing...
Old 18th February 2012, 02:59 PM   #1648
buzzforb's Avatar
Enjoy!!!
I have some Sikorels on the way that i will pit against the Nichicon KG. I also will be trying PRP. If i can tell a difference over Kiwame, i will go for Tx2575.
Old 18th February 2012, 04:08 PM   #1649
qusp is offline qusp  Australia
qusp's Avatar
nice work on the enclosure Evan, you really should make yourself an LOD for the ipad to replace that mini2mini. if you need instructions or a dock connector let me know i'll send one to you. ive started working on mine again for a bit of fun, mainly to use up some tx220 in 4R i have acquired an abundance of and also because ive stuffed it with such premium parts it would be a shame to not use it before deciding whether or not to flip it on. as ive said before, i dont really need a buffer, but its such a cool OTT design
Old 18th February 2012, 04:23 PM   #1650
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Cool way to mount it in a wooden board. Nice. Big speakers, efficient doublets I suppose. What is the voltage gain of the amp and the speakers SPL/1W? Is the volume range practical with a buffer?
dcb1 buffer with shunt reg. merlin2069er Swap Meet 0 3rd August 2010 06:25 PM
F2 and DCB1 parts selection - please advice! DQ Pass Labs 6 25th November 2009 04:20 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 08:40 AM
Copyright 1999-2017 diyAudio
