Go Back   Home > Forums > Source & Line > Analog Line Level
Old 12th February 2012, 03:25 PM   #1631
Reality first!
ClaveFremen's Avatar
Originally Posted by VT67 View Post
Do the Cerafines have preference over the Nichicon's?
IMHO, yes
Dario
ClaveFremen "Bailando Salsa en el Sietch" - My_Ref Fremen Edition GB Second Run
Old 12th February 2012, 03:27 PM   #1632
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
What about Silmic II? Some also like them terminating the regs at the 100uF positions.
Old 12th February 2012, 03:34 PM   #1633
VT67 is offline VT67  Belgium
VT67's Avatar
Because I had those at hand I already raised that question. Answer: See post #1624
Walter
Old 12th February 2012, 03:44 PM   #1634
Salas's Avatar
You will see in your system contex what will fit you best after familiar enough with the buffer added I guess. Keep a choices arsenal, but its always safe to start with tips of those who have been there before. I preferred BGNX to cerafine when they were available, but alas, now its an irrelevant tip.
Old 12th February 2012, 03:58 PM   #1635
Reality first!
IMHO, Silmics II adds reverbs that are not present on signal.
Since in my system a buffer isn't strictly necessary, I've checked againt a simple SMD stepped attenuator (identical to the one used on the DCB1).
I do agree, in fact I'm using Black Gate STD and PKs on leds, second best were Cerafines.
Dario
Old 12th February 2012, 04:11 PM   #1636
Salas's Avatar
Did you try Nichicon Muse also?
Old 12th February 2012, 04:16 PM   #1637
Reality first!
Yes, the higher grade Nichicon KZ (they were the first caps mounted) and they sound very good too (full and pleasant) but in the long term they sound somewhat confused Vs other caps.
I've had the same feeling in every place I've used them...
I've recently tried also the green bipolar ones in the DCB1, too much warm.
Dario
Old 12th February 2012, 04:19 PM   #1638
Salas's Avatar
I have a few Panasonic Pureism PXL 16V but 470uF sadly.
Old 15th February 2012, 06:27 PM   #1639
ggetzoff's Avatar
Took the plunge and am waiting for my full kit with black PCB from TB. I'm going to try the vishay foils (TX2575) I want 4 for the 220R values, should I get more for any other position on the board?
Thanks,
Greg
Airline Pilot-If it's not Boeing I'm not going.
"Brain as big as a planet..." {sic} Nelson Pass
Old 15th February 2012, 06:30 PM   #1640
Salas's Avatar
No.
dcb1 buffer with shunt reg. merlin2069er Swap Meet 0 3rd August 2010 05:25 PM
F2 and DCB1 parts selection - please advice! DQ Pass Labs 6 25th November 2009 03:20 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 07:40 AM
Copyright ©1999-2013 diyAudio
