Salas hotrodded blue DCB1 build
Old 23rd January 2012, 10:40 PM   #1601
weskoki is offline weskoki  Europe
weskoki's Avatar
Thanks Dario i will try the Caddocks!
Old 23rd January 2012, 10:44 PM   #1602
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
They liked thick film resistors in SIT amp as load over wire wound also.
Old 23rd January 2012, 10:53 PM   #1603
VT67 is offline VT67  Belgium
VT67's Avatar
@Dario
Thanks for the info.
As I was placing an order with Mouser just now I noticed they ran out of 2SK170B
Old 23rd January 2012, 11:07 PM   #1604
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
You're welcome
I've had a similar experience with the output resistor of the MyRef...
Between Caddocks MP, Xicon cement wire and Mills MRA the Mills where the less detailed and more confused.
I can't figure out why I didn't tried them earlier on the DCB1...
Dario
ClaveFremen "Bailando Salsa en el Sietch" - For My_Ref FE 12th GB extra boards PM me.
Old 23rd January 2012, 11:25 PM   #1605
VT67's Avatar
I'm tempted to order some 3R3 of those Caddock's and make me a good hotrodded DCB1
Old 23rd January 2012, 11:29 PM   #1606
Reality first!
Take in account that those Caddocks need an heatsink, particularly if you go higher with current.
This one is suitable for 10R and maybe also for 3R3, but it should be verified:
532-577202B00
In this moment I'm using them without heatsink and temperature is 47C
Dario
Old 24th January 2012, 06:30 PM   #1607
VT67's Avatar
OK, so I ordered the 2SK170 from Reichelt. Now I'm gonna thinker a bit about those Caddock's before I place my Mouser order
Old 29th January 2012, 01:53 AM   #1608
sorue is offline sorue  Singapore
How's everyone enjoying their DCB1?
Been having a blast with mine these few months, it's simply wonderful. But the time has come for me to take it one step up, hehe.
I'm ordering a TKD 2S2511 25k attenuator to replace the valab/gigaworks stepped one i've been using. i still don't trust the chinese fully
I've read that the 25k resistance TKD lists is for BOTH channels, combined. Is that the standard naming system? I've always thought that it is PER channel. Correct me if i'm wrong.
I'm looking at upgrading the resistors as well. I've followed some of the posts and want to confirm if the most critical resistor spot are the 220R? TX2352 are going to cost a pretty penny, i don't think i can afford those. I wonder if swapping all the resistors out for PRPs is a good idea? Or maybe one of the cheaper caddocks like the MK132/MK930 for the 220R and PRP for the rest?
By the way, anyone knows why percy only has 221R, no 220R? PCX is the opposite. Or can i use 221R as a substitute for 220R?
Old 29th January 2012, 09:05 AM   #1609
R.I.P.
220 is from the E3 series of values. That makes this value freely available for many different electronic components.
221 is from the E96 series of values. That makes it very rare to be made or kept in stock for any electronic components.
Yes, it can be used as a substitute for a 1%, or 2%, or 5%, or 10% tolerance 220r, but not as a substitute for a 0.5%, nor for a 0.1% tolerance 220r.
regards Andrew T.
Old 10th February 2012, 11:24 PM   #1610
VT67's Avatar
The amp is completely built up, the only thing I'm struggling a bit with is the attenuator. I have a 10K ALPS lying around but want to order a TKD, still haven't figured out if it will be a 10K or a 25K. Any suggestions?
Salas hotrodded blue DCB1 buildHide this!Advertise here!
dcb1 buffer with shunt reg. merlin2069er Swap Meet 0 3rd August 2010 05:25 PM
F2 and DCB1 parts selection - please advice! DQ Pass Labs 6 25th November 2009 03:20 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 07:40 AM
