| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#1591 |
The Dale NS5's are also 20ppm, don't know about the Kiwame's. Not much information found about this particular spec.
I have a question about the relay. Is this Panasonic Low Signal Relays a good substitute for the Omron? Regards Last edited by VT67; 22nd January 2012 at 03:08 PM. |
#1592 | |
Reality first!
BTW they're carbon film so you can expect a much higher one (350ppm). I've tried Mills in that position and they sound good but they somewhat hide details. I'm going to try Caddocks MP930 next week.
Dario ClaveFremen "Bailando Salsa en el Sietch" - My_Ref Fremen Edition GB Second Run |
#1593 |
I'm looking for a bit fuller sound that's why i asked for opinion.
#1594 | |
Reality first!
Very important are also the signal resistors and the 100uF caps.
#1595 | |
Regards |
#1596 |
not politcally affiliated
I use those. They work fine.
Salas Boards 2013 #2 CLICK HERE | F6 Covertible PCB GB Boards Available |DCB1 boards and KITS available PM|SemiSouth R125, R100, R100A Available CLICK HERE |F5TC Boards Sign UP CLICK HERE |
#1597 | |
Congrats Jay, it looks excellent, well done!
#1598 | |
Reality first!
Mounted them some hours ago... wow!
In tha last months I've used a crossover MOX to recover from the closed and no much detail given by Mills, but those MOX had a bit of harsness that I couldn't manage to remove fiddling with other components... The Caddocks are simply right: full and open, detailed, never harsh, gorgeous voices. Soundstage wider and deeper too. The best money I've spent on the DCB1! ![]() Quote:
#1599 |
What resistance did you use? They are pricy though.
Regards |
#1600 |
Reality first!
10R
Yes, they are (7.95$ each from PCX)... but not incredibly more than Mills (2.50$ each from PCX) that are widely used with the DCB1. The sound difference is worth 3x price? IMHO absolutely yes... At the end they're 10 bucks more... a couple of good quality beers, isn't it?
| dcb1 buffer with shunt reg. | merlin2069er | Swap Meet | 0 | 3rd August 2010 05:25 PM |
| F2 and DCB1 parts selection - please advice! | DQ | Pass Labs | 6 | 25th November 2009 03:20 PM |
| Y B Blue - how blue LED improves the CD playback | Peter Daniel | Digital Source | 176 | 25th September 2003 07:40 AM |
