| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#1571 |
Hi everyone
Sorry for noobie question here…. I just finish up the build Hypnotize Black version But first three LEDS light up fine(both Channels) but second Five LEDS(both channels) not lit up and regulated voltage is +18.3V and 18.3V…(Im using Hammond 12-0-12 2AFor testing) seems like regulator does not work properly… using 10ohm resistors for current limiting… I checked LEDs polarity several times… and others like TR and resistors too… Relay works fine I checked each five LEDS banks and it lit up fine individually, but not lit up all five LEDS altogether. I really appreciate any help Thanks John |
#1572 |
diyAudio Chief Moderator
In the 5 leds strings the cathodes (shorter legs, aligned with flat rim cut D on led bodies) must go to the round pads. Is it so?
#1573 |
Hi Mr. Salas,
Thank you for quick reply. Yes I checked several times already, for 5 banks of LEDS directional is OK. If I connect battery each LEDs, it works fine though. Should I change the TRs and FETs ??? Thank you |
#1574 |
Maybe you miss 1 Ohm resistors or simply jumper links where it has a resistor symbol with ''1'' in it?
#1575 |
Hi Mr. Salas,
Problems solved I recheck it and each one contains one Bad Leds Change to new one works great !!! Thank you again I really appreciate your contribution ti this diy comunity. John |
#1576 |
![]() You listen to it already? |
#1577 |
Not yet I just confirmed regulator works! Voltages are within range and output DC offset looks good. will connect and listen it soon. Cant wait....
hopely +18, -18 did not damage anything..... Thanks |
#1578 |
If your relay clicks, regulator voltages are around 10V each and the DC offset on output is good, I don't see any grounds for it had suffered possible damage. Let us know how it went and post a picture also if possible when it will test alright.
#1579 |
Hi Salas, built my 1st DCB1(hotrod) and on one side the 5 led don't glow(and they are right position,no error)nothing hot or smoke and relay work. Start it with variac and stop at about 85AC on 120AC. What transistor is wrong ? Thank's
Praudio |
#1580 |
If you are sure everything is assembled in order, check the CCS Mosfet of the bad side first.
| dcb1 buffer with shunt reg. | merlin2069er | Swap Meet | 0 | 3rd August 2010 05:25 PM |
| F2 and DCB1 parts selection - please advice! | DQ | Pass Labs | 6 | 25th November 2009 03:20 PM |
| Y B Blue - how blue LED improves the CD playback | Peter Daniel | Digital Source | 176 | 25th September 2003 07:40 AM |
