Salas hotrodded blue DCB1 build - Page 141 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 12th October 2011, 04:03 PM   #1401
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
Originally Posted by boatbuilder View Post
maybe this is a st@p$d question, but if this is the hotrodded version, than what is the original and where can i find it?
kind regards, Mat
Not stupid.
The hot-rodded version is evolution of the original, but not all that different.
The original circuit can still be had with the Mezmerize available at the Diyaudio store.
P-MEZB1-1V10e - Mezmerize B1 Buffer Preamp (Makes 2 channels; Rev 1.0) - Boards
Salas Boards GB 2017#1 ON ORDER | GB 2017 #2 Click Here to Sign Up! | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards On ORDER
Old 15th October 2011, 02:42 AM   #1402
cersepn is offline cersepn  United States
Originally Posted by Salas View Post
What happens if you swap channels?
Thanks for the advice. After i swapped channels.. that was when i realized something was amiss. After swapping in different preamps and sources, i found out it was actually the amp with a dead channel
It must have gone dead when i unplugged the right DCB1 channel live and heard the boom sound.. Was fine before that. Not too sure what to do now
Old 15th October 2011, 02:44 AM   #1403
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Now we know. Sorry about your amp. Never change plugs live, its a classic trap. Is it under warranty?
Old 15th October 2011, 02:51 AM   #1404
Thankfully it is. I'm hoping it was the protection circuits kicking in and shutting down that channel, and no permanent damage was done. I'm really glad that i finally found the true cause of the problem though
Old 15th October 2011, 02:54 AM   #1405
Salas's Avatar
Could be just a fuse if you got lucky.
Old 21st October 2011, 07:19 AM   #1406
komigenie's Avatar
Never mind ... Delete post
Old 28th October 2011, 10:16 PM   #1407
Skywave-Rider's Avatar
I plan to use 2 of these to switch outputs as well as ins, to feed different amps conveniently. Any issue with switching outs while the unit is operating?
Old 28th October 2011, 10:22 PM   #1408
Salas's Avatar
This unit no issues but the following amps maybe.
Old 28th October 2011, 10:29 PM   #1409
Thank you. Currently I use this on my old preamp:
That's just a passive switch, no problems with my current amps; so maybe I'll be ok. Thanks.
Old 29th October 2011, 01:03 PM   #1410
DimZ is offline DimZ  Greece
done some upgrades ..
mills 9.1R, tx2575 220R and put it in a case ..
one led tripled (irfp 9240 side) dont work and the 9.1R Mills run extremely hot ....
dcb1 buffer with shunt reg. merlin2069er Swap Meet 0 3rd August 2010 05:25 PM
F2 and DCB1 parts selection - please advice! DQ Pass Labs 6 25th November 2009 03:20 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 07:40 AM
Copyright 1999-2017 diyAudio
