| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#1271 |
Progress...
#1272 |
Nice case, where did you get it customized?
#1273 |
Thanks!
The front panel and side flanks come from Modushop, Cam-Expert did all the panel work. |
#1274 |
I like the flames. Nice touch!!
#1275 |
Newbie
Looks like you are getting really close John. Great work!
#1276 |
diyAudio Chief Moderator
#1277 |
Are those aluminium plates enough for Hot rod?
#1278 |
Will take enough, but he will know how much is comfortable only in the end. I would not let the plates go more than 45C, because they can be slowly ''frying'' the goods like a pan in the long term. Must spot check plates area under the PCBs with a temp measurement thingy.
#1279 |
I am visiting and using someone else's computer.
I had to wait about 6minutes for this page to download. The message that repeatedly flashed up was: "receiving data from i.imgur.com" Now I find that four new images have been posted by Johnw on a remote server. When is this practice going to be barred? |
#1280 | ||
Thanks guys!
DaveM you have a keen eye ![]() Quote:
I was fairly diligent sanding back the base and al plates adding thermal grease between etc, I’m hoping for a good transfer of heat to the large 350 x 435mm base panel. Quote:
| dcb1 buffer with shunt reg. | merlin2069er | Swap Meet | 0 | 3rd August 2010 05:25 PM |
| F2 and DCB1 parts selection - please advice! | DQ | Pass Labs | 6 | 25th November 2009 03:20 PM |
| Y B Blue - how blue LED improves the CD playback | Peter Daniel | Digital Source | 176 | 25th September 2003 07:40 AM |
