Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#1241 |
diyAudio Chief Moderator
Creative use of redundant positions, nice. With 12V reg straight to the input relays I think there were no erratic denials from the input selection actions in the MEZ.
#1242 |
Before i mount my lvl 1 hot rodded dcb1 into the chassis, i was wondering if it would be better to use the bottom of my chassis (bottom alu sheet measures ~ 350mm x 430mm x 4mm thickness) as the heatsink instead of the heatsinks that i'm using right now. I realize with these heatsinks i can only rest my finger there for at most 5 seconds - it is really quite hot.
#1243 |
You changed signal resistors to Texas and Caddock? Nice pic. Since the chassis floor is 4mm and the box normal size, better sink them there.
#1244 |
Haha, actually that's not my dcb1. I stole it off someone else here
![]() those vishays are definitely in the pipeline though |
#1245 | |
By lvl1, did you mean using 10 ohm resistors for 200 mA?
#1246 |
Yea, 10 ohm - 200 mA. Will that be a problem?
#1247 |
#1248 |
Measure your sinks, if they don't go over 55C, they could make it. Punch ventilation holes on the box under and top of them.
#1249 |
#1250 |
not politcally affiliated
Yes, otherwise they are typically 2W's.
Some Salas Boards In stock, PM | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards PM for sign up | Sony VFET CSX2 AL boards Shipped | Vishay/Harris MOSFETs Click Here to Sign Up! |
Thread | Thread Starter | Forum | Replies | Last Post |
dcb1 buffer with shunt reg. | merlin2069er | Swap Meet | 0 | 3rd August 2010 05:25 PM |
F2 and DCB1 parts selection - please advice! | DQ | Pass Labs | 6 | 25th November 2009 03:20 PM |
Y B Blue - how blue LED improves the CD playback | Peter Daniel | Digital Source | 176 | 25th September 2003 07:40 AM |
New To Site? | Need Help? |
