| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#1231 |
#1232 |
Then the relay has no trigger signal.
That could be the transistor switch that is not working or some other faulty component. You need to now measure back through the relay drive circuit to find where the error starts. |
#1233 |
I have some of these left around:
Dayton DNR-10 10 Ohm 10W Precision Audio Grade Resistor 10 ohm 10 W sandcast. Would it OK to replace the parallel 68 ohm so I can bring the current to 200 mA?
#1234 |
not politcally affiliated
Yes, that's fine.
Salas Boards 2013 #2 CLICK HERE | F6 Covertible PCB GB Boards Available |DCB1 boards and KITS available PM|SemiSouth R125, R100, R100A Available CLICK HERE |F5TC Boards Sign UP CLICK HERE |
#1235 |
diyAudio Chief Moderator
Surely the ''note'' jumper for a 12V relay is installed?
#1236 |
You are referring to the relay circuit ground return link, located elsewhere on the PCB.
#1237 |
Thanks for the help guys, turns out it was the BC550. All working fine now thanks. David
#1238 |
#1239 |
#1240 |
both those resistors are in parallel. Only one is needed to supply the relay coil.
I have split those resistors in a MEZ build, one feeds the mute/unmute relay with 15Vdc from a 7815 using 2k as the dropping resistor. The other feeds the selector relays. I use 1k here, but without the current boost at start up sometimes the relay does not fire. All I do is turn the selector and then the (or any) relay always triggers on re-selection. In my Hyp build I used one resistor to feed the relays and the other resistor to feed the current boost. Again that was 15Vdc into a resistor fed 12V relay. |
| dcb1 buffer with shunt reg. | merlin2069er | Swap Meet | 0 | 3rd August 2010 05:25 PM |
| F2 and DCB1 parts selection - please advice! | DQ | Pass Labs | 6 | 25th November 2009 03:20 PM |
| Y B Blue - how blue LED improves the CD playback | Peter Daniel | Digital Source | 176 | 25th September 2003 07:40 AM |
