Salas hotrodded blue DCB1 build
Old 9th June 2011, 03:45 PM   #1111
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
The LED thing is was counterintuitive to me at first. But, have to put the LEDs in reverse polarity, because of the nature of other stuff in PS.
Salas Boards 2018#1 On Order | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards, PS and transformers Available PM | Sony VFET CSX2 AL boards In Stock
Old 11th June 2011, 01:49 AM   #1112
nezbleu is offline nezbleu  Canada
nezbleu's Avatar
I don't understand that comment. The LED's are forward-biased, that's why we care about their Vf. When I look at the schematic I don't see the LED's "in reverse polarity".
Old 16th June 2011, 08:21 PM   #1113
Builder Brad is offline Builder Brad  United Kingdom
just swapped out the current limiting resistors for 2.7 ohm wirewound ceramics. Measured 1.1v scross the negative side, which yields about 400ma. feeling the heat now. not sure if my dmm reading is really accurate as I need to change its battery - could be nearer to 600ma
for some reason I have lost the + side. the bank of 3 resistors is still lit but the bank of 5 are not lit. the relay still works. any ideas on what has blown?
its getting warmer here in the UK, so I want to see how far I can push the B1. the - side is not getting especially warm with the 2.7 ohm resistors. I have 1 ohm on standby once I sort out the + rail problem, still sounds good on 1/2 of its potential though.
Brad
Old 16th June 2011, 08:27 PM   #1114
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Either one led of 5 (or more) or the jfet underneath, or the output Mosfet. See if there is Vgs in output Mosfet. Then turn it off and check if every led can alight with a 1.5V battery one by one, or with diode checker on dmm.
Old 18th June 2011, 06:43 AM   #1115
Hi Salas,
all the LEDS are ok.
looks like either the MOSFET, of the 1st JFET. on the working side from the input end of the PCB I measure -21v,-9.5v and -24.5v the non working side gives 26.9, 26.9 and 21.6. the 1st SK170 reads -21.2, -21.2 and -0.7. the non working one gives 21.8, 0.7, and 0.7.
best Guess? I say JFET! what do you think?
Brad
Old 18th June 2011, 06:49 AM   #1116
Salas's Avatar
Well, its the easiest to replace first and see anyway.
Old 18th June 2011, 10:27 PM   #1117
just replaced the SK170 JFET - no difference.
wonder if I should look to change the 1st or 2nd stage MOSFET next?
Old 18th June 2011, 10:52 PM   #1118
Salas's Avatar
Look if there is about 3.5-4V between their G,S first. If there is not, its a problem.
Old 19th June 2011, 01:38 AM   #1119
cheers Salas,
here are the readings working MOSFET on negative side -21v,-9.5v and -24.5v the non working side gives 26.9, 26.9 and 21.6
Brad
Old 19th June 2011, 01:42 AM   #1120
Salas's Avatar
Measure Vgs on each non working side MOS individually. Pins 1,3 on each.
Salas hotrodded blue DCB1 buildHide this!Advertise here!
dcb1 buffer with shunt reg. merlin2069er Swap Meet 0 3rd August 2010 05:25 PM
F2 and DCB1 parts selection - please advice! DQ Pass Labs 6 25th November 2009 03:20 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 07:40 AM
