Go Back   Home > Forums > Source & Line > Analog Line Level
Old 21st August 2010, 12:30 AM   #101
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by RichLund View Post
I remember the size of the bloody bouncers!
Sorry folks, Salas and I heading down memory lane is diverting the thread a bit.
Good work Salas. Keep it up fella
I remember the white older head bouncer guy and the two massive blacks. The leader would just say ''another night gentlemen'' if he was not to get us in. If we asked why, he would have replied ''drugs''. Then we were off to Archies. No further argument.
Cheers.
Old 21st August 2010, 12:45 AM   #102
Salas's Avatar
Originally Posted by wendell c View Post
Thanks for the info Salas, will pull the trigger on that tx and pull the cutter out
You are welcome.
Old 21st August 2010, 12:46 AM   #103
Salas's Avatar
Oh, and thanks for this info. I was hoping to use a spare 30VA 18-0-18 traffo just to get me going. This helps a lot.
Cheers
Keep those CCS set resistors 10R 5W in your case.
Old 21st August 2010, 01:47 AM   #104
dvb-projekt's Avatar
Send a message via Skype™ to dvb-projekt
Any recommendations for the CCS resistors if i want to add my Lightspeed/OVC pcb to the DCB1?
Could i stay with the 2x47R (1x22R) or should i lower the value a bit?
Reference TDA1541A DAC project PCB´s / Tube-I-zator PCB / SSHV-Shunt PCB
Stock status in my Blog
Old 21st August 2010, 02:08 AM   #105
Salas's Avatar
You want to make a low CCS running DCB1 plus tap off for powering an optivol if I understood correctly? What is the consumption of optivol?
Old 21st August 2010, 02:53 AM   #106
That´s really funny... After 10 month of Lightspeed/Optical Volume Control pcb GB, i had finished my first own pcb in July.
Since than i don´t power it up. So i must measure the max. current it needs...
Perhaps you could tell me the current of the DCB1, so i could calculate the resistor value myself.
If i am not wrong both currents + 20% for the shunts, right?
Old 21st August 2010, 08:49 AM   #107
Salas's Avatar
Depending on LEDs Vf and Vgs of Mosfet it can be 70 to 90mA for 47 parallel 47.
Old 21st August 2010, 09:05 AM   #108
LucasAdamson's Avatar
Yes, I have added a link about that flick too.
3.978k in total. Add one in series to the 3k3 that will get it about there, or make some other new combination from paralleled ones, whatever.
Oh yeah, so you did!
Salas, you are a shunt reg God! Thanks a million for all your help!
Lucas
Old 21st August 2010, 11:06 AM   #109
I have measured the max. current of my OPC board... 61,5mA
Old 21st August 2010, 12:16 PM   #110
8.80-8.79-8.76-8.77
Yes,
and the output offset should be a tiny -ve value to confirm that you have them in the correct positions for both channels.
If the higher Idss is in the CCS position the output offset will be a tiny +ve value. If the output offset is a big +ve value, your B1 is in trouble.
dcb1 buffer with shunt reg. merlin2069er Swap Meet 0 3rd August 2010 05:25 PM
F2 and DCB1 parts selection - please advice! DQ Pass Labs 6 25th November 2009 03:20 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 07:40 AM
Copyright ©1999-2013 diyAudio
