| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
Thought of sharing this just-published article with friends on DIYAudio. If you happen to get hold of this issue and read the article, please feel free to ask questions or shoot feedback. The first para of the article appears below. The article itself is only a summary of 2 pages, but does have plenty of schematics. "Active (crossover) filters are not a new idea, having been around for decades. However, if you are on the lookout for an all-analog filter that offers the ability to continuously vary the crossover frequency via a simple front panel potentiometer, the choices are limited. Furthermore, if you also want the flexibility to play around with different transfer functions—again, by simply flipping a front panel rotary switch—your choices narrow down still further. These twin requirements led me to design the AF-108 continuous-time active filter."
Last edited by Dr. Ram; 29th July 2010 at 05:14 AM. Reason: Attached an image of the filter. |
#2 |
I gather that you are the designer of the unit and the author of the article?
jd
/Yes! Its out: Linear Audio Vol 5! I'm not an "accademic", just a plodder who loves a challenge - Ian Hegglun |
#3 |
#4 |
What you have built looks very nice. I have not yet read your article in aX, but I will look for it in my local bookshop.
As for how to implement a second order HP/LP transfer function, there is an IC that will do this, is time continuous, and is readily available: the UAF42 from Burr-Brown. I use this in various filters used for active speakers and other things. Q and crossover frequency are continuously adjustable via external potentiometers (one dual channel, one mono). Is this what you use in your project/product? -Charlie |
#5 | |
-Ram |
| Hi Res 550mm Fresnel Lens Set, 15"x11" First Surface Mirror, 6.3" IR/UV Filter, More! | Ben_Tech | Swap Meet | 0 | 22nd September 2007 10:49 PM |
| AudioXpress August 2006 - "Equalize the Bass Response of Your Room" | ergo | Multi-Way | 0 | 12th April 2007 07:35 PM |
| Noob question : what exactly is the "Q" of an active filter ? | youyoung21147 | Chip Amps | 7 | 10th December 2005 09:39 PM |
| "transient-perfect" crossover in 12/02 AudioXpress | dorkus | Multi-Way | 41 | 25th November 2002 07:23 PM |
