The "Make Before Break" connection for audio interconnects (MBB configuration) - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 27th June 2010, 03:15 PM   #1
neazoi is offline neazoi  Greece
Default The "Make Before Break" connection for audio interconnects (MBB configuration)
An idea,
K.Giannopoulos official site
I would like your comments
Great DIY site: http://www.neazoi.com
Old 27th June 2010, 03:22 PM   #2
aptquark's Avatar
Sure why not. It's one of those things where the industry has been using the RCA forever...and its almost by default that it is used. Similar to the XLR. Of course, the XLR has its own unique advantages. Hell, I would prefer no connectors if practical.
ARXIDI!
Spiro
Old 27th June 2010, 07:37 PM   #3
thank you,
by the way do not say that word it is really bad and you will probably get punched haha
Old 27th June 2010, 07:42 PM   #4
aptquark's Avatar
Originally Posted by neazoi View Post
thank you,
Yea...probably by another Greek!
Old 27th June 2010, 08:18 PM   #5
Steve Eddy's Avatar
An idea,
I have a much simpler and elegant solution than re-doing all your cable and component connectors for BNCs and hoping the industry adopts them as a new standard.
DON'T SWAP YOUR CABLES OUT WITH THE SYSTEM POWERED UP!
se
Old 27th June 2010, 08:28 PM   #6
se
As I said, there is a series of advantages that BNC offers over the RCA, not only the MBB.
I am talking about designing an audio system to achieve the best. Of course one could switch off his equipment but... why do we need to do so when there are better alternatives?
A little bit of thought
Old 27th June 2010, 08:29 PM   #7
Dr_EM is offline Dr_EM  United Kingdom
Dr_EM's Avatar
I doubt BNC has sufficient current handling for most speaker connections, but for line level it'd be fine.
Old 27th June 2010, 08:31 PM   #8
Yes that is entirelly correct! I have defined now in the article that it should be good for a low power amplifier.
BTW the tiny SMA connectors, which have thinner internal conductor than BNC, can handle up to 50W of RF power, should this give you a measure of the power handling of a BNC for audio...?
I found in an article that the power handling of a BNC is 80 Watts at 1GHz, if this is the same for audio it is more than enough for most room listenners..
Thank you
Old 27th June 2010, 08:52 PM   #9
Steve Eddy's Avatar
Fair 'nuff.
Though what if one feels that balanced interfaces achieve the best?
se
Old 27th June 2010, 08:57 PM   #10
Fair 'nuff.
se
Sure, I am open to this conversation too if you wish to discuss it
What makes Nichicon "muse"/"for audio" caps different ? percy Parts 2 3rd October 2009 05:53 PM
Linear voltage regulator: how to make good use of "sense" and "ground sense"? NeoY2k Analog Line Level 7 6th September 2008 11:35 PM
Does anyone know the brand "QED" for cables & interconnects? Bricolo Parts 7 25th June 2003 09:32 AM
How to make Audio and Video Interconnects Bthompson Everything Else 0 20th April 2003 10:13 PM
Copyright 1999-2017 diyAudio
