Volume / Source selector - open source project ? - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 17th June 2010, 11:51 AM   #11
maxw is offline maxw  United Kingdom
maxw's Avatar
Sounds good. I have schematic and layout for input selector. I'll post it when I get home.
Old 17th June 2010, 10:38 PM   #12
maxw's Avatar
Here is the Input selector I am making a PCB for. I'll use SMT ICs and also SMT omron g6k relays.
Old 17th June 2010, 10:56 PM   #13
Geosto is offline Geosto  Netherlands
What I think is missing in the list is the balance controller.
If you want to do well, then the left and right channels to be separately controlled by the controller.
Prevented then an extra circuit in the signal path.
You would have a chip that can have 16 relay switch.
Regards George
Old 18th June 2010, 01:39 PM   #14
danzup is offline danzup  Romania
danzup's Avatar
Default My proposition
This is my idea of Input selection
There are not better tube than 6P3S and 6N2P for my ears !
Old 18th June 2010, 02:24 PM   #15
promitheus's Avatar
For balance control you only need to do it with software.
You could even do it with the volume control knob.
Old 18th June 2010, 02:25 PM   #16
maxw's Avatar
That would work, be more simple. You'd need some switches or jumpers to set the address and make sure to use relays that sink less current than that IC can allow.....which is 25mA I think???? Omron g6k were the lowest power relays I could find that were readily available but perhaps you know a better one? They are about 21mA I think.
Old 18th June 2010, 02:32 PM   #17
maxw's Avatar
Actually, can any of the pcf8574 ICs supply enough current to drive 6x relays @ 21mA simulataneously? I'm not sure how to interpret some of the ratings in the datasheet but noticed most other designs use a ULN23008 for this reason.
Old 18th June 2010, 02:34 PM   #18
promitheus's Avatar
yeah, why not use a driver or simply transitors its safer as trying to drive all relays with the Processor.
Old 19th June 2010, 04:48 AM   #19
danzup's Avatar
It is like this : every pin can sink 25mA .
I am agree that jumpers for address are needed sometime.
I have tested with a lot of relay , direct drive : Takamishawa , Siemens and Omron at 5V are in between 15 mA ... 22mA Ireq wich is in the range .
Old 13th August 2010, 09:53 AM   #20
maxw's Avatar
Danzup, did you finish your project?
I have finished my version, works well! Here is some pics.
CDPRO2 Group Project (open source project) BrianGT Digital Source 147 8th August 2008 12:37 PM
source selector / volume hum in Aikido cbutterworth Tubes / Valves 1 28th March 2007 08:34 AM
Let's create an 'open source' hardware project. gmarsh Digital Source 41 6th October 2006 01:42 PM
Open-source DSA project borges Digital Source 8 24th September 2006 08:26 AM
Copyright 1999-2017 diyAudio
