volume remote control module with PGA 2311
Old 7th February 2013, 12:55 PM   #151
FarmTech is offline FarmTech  Denmark
FarmTech's Avatar
Send a message via MSN to FarmTech volume remote control module with PGA 2311
Originally Posted by KatieandDad View Post
No mine is as per your diagram. Supplied by the same Chinese supplier. I just assumed it was a PIC.
ok,
Don't know if your board have same pin layout as mine see my link to Board
You have to get a new chip ATMEGA8515 and program it with the code
and make the change on the pcb as in post
you can use many diffrent programmers for this
I use Bascom-avr and Atmel Studio
/Kim - Bascom-AVR user >> My WebChat
My Web Site
Old 7th February 2013, 01:06 PM   #152
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
Yep, Mine looks exactly the same, just the markings on the micro are different.
Question was, How do you reprogram the new micro ?
If I need to buy a PIC (or whatever) programming board and the software to go with it, it ain't worth it. Dusty Bin can have a feast.
I only paid £19.00 for the cr*p kit in the first place.
Old 7th February 2013, 01:20 PM   #153
FarmTech's Avatar
You need a programmer to program the chip and Fusebits
software for programmers are free on net , just be sure that the programmer can program fusebits Atmega8515 is default 1Mhz int we run 8Mhz int
I dont have time to make a long list of programmers and software so check the web for it
How can I help :
if you like I can program a chip and ship it to you
all you need is pay for chip and shipping cost from Denmark
or you can send me a chip (ATMEGA8515) and I program it) and ship back to you
before you do this check post #1 schematic to be sure it's same layout
My Web Site
Old 7th February 2013, 01:36 PM   #154
I've had to send the kit back to China for the time being. The PCB that I bought had the rectifier diode silk screen orientation round trhe wrong way which caused a bit of damage. The vendor wants to see the boards.
How much would a programmed chip be ? I might just sent the kit to you so that you can verify your work before you return it, that would save any animosity due to confusion.
What crystal is on your PCB ? Mine has a 12MHz crystal.
Old 7th February 2013, 01:47 PM   #155
FarmTech's Avatar
around 10£ inc shipping cost (5.8£)
crystal is same but I see 1 Cap to lcd backlight the yellow one left site
and connectors top right is not same
but that dont mean its not same chip pin layout as mine
about the rectifier diode maybe the PGA2311 is dead from this error wrong power in +-5V
My Web Site
Old 7th February 2013, 01:58 PM   #156
I think the regs protected the PGA2311. They did not output anything with reverse polarity input.
I was amazed, the two regs smoked like a burning building but were both still OK after testing. I only applied the reverse power for less that a second.
Anyway, hopefully Chinese vendor will sort that out as that was his mistake. You will notice that the four rectifiers are noe apparently the wrong way round (this is how they should be)
£10 sounds fine to me.
Old 7th February 2013, 02:16 PM   #157
FarmTech's Avatar
KatieandDad , do you have sch of the boards ?
then its easy to compare pin layoout of the mcu chip
My Web Site
Old 19th July 2013, 08:05 PM   #158
whitesnake is offline whitesnake  Bulgaria
Hi, KatieandDad !
Can I write your source http://www.diyaudio.com/forums/attac...rmtech_nec.zip
on this chip Atmel at89c52 or I must use ATmega8515 ? Is It works?
Old 22nd February 2014, 10:48 AM   #159
yaumatei is offline yaumatei  Germany
Hello FarmTech,
today i modify my China-PGA2311 and program a m8515 with your code and it works fine. Thank You.
Old 22nd February 2014, 02:49 PM   #160
FarmTech's Avatar
HI yaumatei ,
Tnx for the feedback enjoy it
My Web Site
volume remote control module with PGA 2311Hide this!Advertise here!
Volume control on DVD player remote. Lose resolution at low volume? Circlotron Digital Source 2 10th June 2011 07:20 PM
PGA 2311 Test Circuit HarryK Chip Amps 13 15th March 2011 09:42 AM
Integrated AMP with PGA 2311 preamp kpero Chip Amps 5 26th April 2009 07:05 PM
Remote volume control for existing remote? theAnonymous1 Parts 7 6th August 2007 08:22 AM
