volume remote control module with PGA 2311 - Page 15 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 20th September 2012, 03:50 PM   #141
wushuliu's Avatar
Ah, got it. Thanks Rick!
Old 6th February 2013, 12:29 PM   #142
FarmTech's Avatar
Send a message via MSN to FarmTech Send a message via Skype™ to FarmTech
Originally Posted by Jempie View Post
hi
I have bought by ebay a volume remote control module with PGA 2311
the problem is that the volume starts every time with the volume level of
-46dB and does not remember the volume setting. Also the lowest volume is
-96 dB and you can still hear some sound it must be zero.
a have ask the seller to change the software of setting but the don't give
any correct awnsers. Is there a way to change the HEX file i
Crystal PGA2311 Volume remote control preamplifier kit - eBay (item 200471618932 end time Jun-10-10 20:06:21 PDT)
regards,
Harry
Hey Hendrik,
I'am testing this board now with 8515 seems to work ok
I used Danzup code as base code and edit the layout for the board
when finish testing I post the code for it
/Kim - Bascom-AVR user >> My WebChat
My Web Site
Old 6th February 2013, 12:34 PM   #143
KatieandDad's Avatar
-96dB must be quiet enough to be almost silent. I can't imagine when you would need total silence - turn it off.
My PGA2311 kit from E-Bay has been problematic from the start. For a start it came with no instructions other than "Insert the components as per the silk screen". I did, only to find that the PSU diodes were the wrong way round. It still doesn't work properly. It starts up OK and drops to -96dB. Then it rises to -46dB. From there I can only reduce the volume and not increase it.
Old 6th February 2013, 03:47 PM   #144
linuxworks's Avatar
the ebay controller code tends to be utter crap.
if you want, you can download my arduino source code and adapt the pga engine board to use an arduino (mine is LCDuino) controller. there is a lot more features in my code and you can change the code, too, unlike the ebay/china stuff.
hth
My Photostream:http://www.flickr.com/photos/linux-works/
Old 7th February 2013, 12:31 AM   #145
FarmTech's Avatar
Default Bascom AMEGA8515 CODE for China Board
hi
regards,
Harry
' you need to modify the board a bit for this code see China_8515_sch_EDIT_THIS.PNG
Here is the code for China board using Atmega8515 fuse INT 8Mhz
download Zip file and edit PCB like in SCH
I removed the 4 sil pullups resistor network
and cut the wire at PIN 9 RESET 89C51 use reverse rest so you need to CUT here
' see Yet another Volume controlers and source selections
' this version with 3 input, RC5 remote control & PGA2311 volume ,
' mute ,backlight LED control , with Encoder
' modified time delay for volume set
'Modified by FarmTech 20.09.2010 EDIT INPUT SELECT TEXT via RC5 , leran RC5
' Edit the Text for you input How do it work :
' Select Edit input text via menu button
' Upper Line Show The Current Text
' Bottom Line Is Where You Write The New Text
' RC5 COMMANDS FOR EDIT TEXT :
' STEP 1 : VOL - : SELECT THE TEXT TO EDIT steps from 1 to 3 in the input select text
' STEP 2 : CH + : scroll letters up
' STEP 3 : CH - : scroll letters down
' STEP 4 : VOL + : SELECT the letter , it goes next letter do step 2 to 4 until you have the text you like to use
' STEP 5 : MUTE : save the text to memery and show it on lcd use VOL- to select next or press power on/off to exit
' STEP 6 : Power on/off EXIT Edit mode
' ATT ATT :IF YOU LIKE TO EXIT AND NOT SAVE JUST PRESS POWER ON/OFF -
' 22.09.2010 LEARN a new RC5 Remote controller
' New in menu is add a new remote
' This ONLY work with a RC5 remote
' When you you enter this menu you will be ask to :
' PUSH A BUTTON = this will check if your remote is a RC5( use 1 of the buttons CH+, CH-, VOL+, VOL- or Mute )
' If NOT then it cant be used PUSH menu to exit this setup
' If it is a RC5 you can now add this to controlle your hardware
' Just 5 steps to setup buttons Power, CH+, CH-, VOL+, VOL- & Mute
' Thats it simple and easy enjoy
Encoder push button have 3 funktions :
short press select menu less than 0.5 sec
medium press Mute 1 sec
long press power ON / OFF more than 1.5 sec
LCD show volume as 0 - 63 but we can change it if you like db or 0-128
My Web Site
Old 7th February 2013, 11:27 AM   #146
FarmTech's Avatar
just a update for volume show -96 to +31.5db
My Web Site
Old 7th February 2013, 12:15 PM   #147
I'm completely new to programming of PICs and their bretheren. How do you reprogram the PIC with the hex file ?
Old 7th February 2013, 12:24 PM   #148
FarmTech's Avatar
First of all this is ATMEL not PIC
so if you'r setup is based on a pic I can't help you (sorry)
My Web Site
Old 7th February 2013, 12:27 PM   #149
No mine is as per your diagram. Supplied by the same Chinese supplier. I just assumed it was a PIC.
Old 7th February 2013, 12:49 PM   #150
FarmTech's Avatar
Default China ATMEGA8515 org remote
This is for update ATMEGA8515 with orginal remote (NEC)
Only for orginal remote no edit input text or change remote
I used this board
goto link and see more image of the board
My Web Site
Last edited by FarmTech; 7th February 2013 at 01:04 PM. Reason: added info board link
Volume control on DVD player remote. Lose resolution at low volume? Circlotron Digital Source 2 10th June 2011 07:20 PM
PGA 2311 Test Circuit HarryK Chip Amps 13 15th March 2011 09:42 AM
Integrated AMP with PGA 2311 preamp kpero Chip Amps 5 26th April 2009 07:05 PM
Remote volume control for existing remote? theAnonymous1 Parts 7 6th August 2007 08:22 AM
Copyright ©1999-2017 diyAudio
