Why is this mic eq more cuting than boosting? help
Old 28th May 2010, 09:25 PM   #1
Joseph R is offline Joseph R  Switzerland
Default Why is this mic eq more cuting than boosting? help
I have build this mic preamp with semi parametric eq and it is more cutting than boosting. Cut is around 10db but boost only around 3db. Why?
Old 28th May 2010, 10:37 PM   #2
bob91343 is offline bob91343  United States
Probably because you are using log pots for the controls. Use linear pots and it will likely do what you want. In other words, the 'flat' position may not be in the middle.
Old 28th May 2010, 11:05 PM   #3
mickeymoose is offline mickeymoose  Canada
Well, I must say that I love the connection between pin 2 +3 on the first (left-most) IC (not numbered). Than, I do not know what U1A + B are supposed to do. Please explain.
The tone controls seem to be OK. I would take each section of the circuit and run it through LTSpice individually and see what they do. E
Old 30th May 2010, 01:51 PM   #4
Thanks bob and mickey
The short between pin 2 and 3 is only on the schematic. Not on PCB.
I think that bob could be right. I think I have put a log pot in place of R20 but must be Lin pot.
I have already spiced the whole schematic and it worked fine so it must be a pot problem.
I will go back tomorrow to my workshop and check it.
Old 30th May 2010, 05:56 PM   #5
bob is right, when you use the wrong type of pot at the centre pos it will not give you the same result. But bob is wrong, at the end position you should have the same boost/cut as the other pot. So, maybe, there is a wiring or parts problem somewheere. E
Old 30th May 2010, 09:49 PM   #6
Yep true mickey.
I did some more spice and did find out that if I turn down the input volume R5 the asymetrical behavior is even more pronounced and if I turn full up R5 it is much more symetrical.
I did ad a buffer between R5 and the tone control and it looks to work perfectly. I try this tomorow on the board.
Old 7th June 2010, 03:58 PM   #7
Finally I had some time to fix it. I aded a buffer between the pot and eq stage and it works perfectly with +-15db of boost/cut.
This is what it looks like.
Thanks for your help.
Old 27th November 2012, 05:15 PM   #8
Relz is offline Relz  France
Hi Jospeh you said you got this circuit to work perfectly, I am just wondering did you make any more changes. I also built this circuit with added buffer but i am getting a low frequency hum when using the sweep & bass pot, did you have any other problems?
Why is this mic eq more cuting than boosting? helpHide this!Advertise here!
Mic, Line, EQ... Preamps apexaudio PA Systems 627 7th June 2018 07:37 PM
LM3886, Leach Amp, Active XO, Subwoofer EQ, Mic Preamp, Joshua Tree, FE103E, More! wigginjs Swap Meet 27 20th September 2008 09:32 AM
Signal boosting spots25 Digital Source 3 6th January 2006 01:18 PM
Behringer UB*02: mic preamp + EQ? rick57 Multi-Way 8 17th April 2003 05:20 AM
boosting a boost.. ChesterFuzzin' Multi-Way 1 22nd August 2002 08:20 AM
