Mic, Line, EQ... Preamps - Page 43 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 1st July 2013, 11:08 AM   #421
apexaudio's Avatar
Originally Posted by DAMANHURI View Post
if I'm using a microphone, I get a very big sound and it causes feedback, I want to lower the gain so that the sound is not too big component of what should I change?
shematicnya following:
http://www.diyaudio.com/forums/attac...x-tone-sch.jpg
regards
Increase 100R resistor for lower gain.
Old 1st July 2013, 12:18 PM   #422
csom's Avatar
Originally Posted by apexaudio View Post
Use this wireing connection.
Thank you sir.
But I have a doubt.
Is the blue wire un-connected? Or is it connected to the M+ section?
Also my mic came with a 2 pin jack.
Can this circuit work with a 2 pin jack?
(This will save me from buying another cord or 3 pin jack. )
Could you kindly draw a diagram for a mic with 2 pin jack?
Warm regards, Som
Old 1st July 2013, 04:12 PM   #423
DAMANHURI's Avatar
Thank you Sir Mile, I will try
regards
Best regards - Damanhuri
Old 1st July 2013, 06:44 PM   #424
csom's Avatar
I connected this way now. Please see the attached picture.
Over all gain increased when I shortened M- and Gnd. Earlier ML3 output level was not so good.
ML3 output is louder now.
Equalizer function is very satisfactory.
But some problems.
1. There is very low output even if the volume is zero.
2. Microphone level is still not good at all.
3. Noise and distortion become prominent when I increase ML3 volume to some 70%.
Since so many people have made ML3 and appreciated it a lot, something must be wrong with my build.
Well, I tried my best to fix the mic problem but for me the mic is not upto my expectation or simply unusable though equalizer section is pretty good.
Any help to resolve this issue is much appreciated.
Thank you.
Warm regards, Som
Old 2nd July 2013, 04:07 AM   #425
DAMANHURI's Avatar
Mrm Mile :
what if I want to add a send-return models for Vocal Effect?
Old 19th July 2013, 11:16 PM   #426
desislavov's Avatar
But some problems.
Thank you.
I think that the blue wire from mp3 must conected to GDN too ....
You have line + and line - this mean that is balanced input
I`m right sir mile ?
Old 7th August 2013, 04:23 AM   #427
Smile ML3 with 4 input
Mr. Mile, i want to build my ML3 with 1 line in, 3 mic pre amp n each level in 1 tone control. How about my picture? Thanks.
Old 7th August 2013, 04:45 AM   #428
Default ML3 with 4 input
Mr Mile, can i build ML3 with 1 line in 3 mic preamp with each level in 1 tone control? How about my picture? Thanks.
Old 5th September 2013, 01:05 PM   #429
can I use this kit for guitar preamp?
Old 23rd November 2013, 07:33 PM   #430
Send a message via MSN to dey_anjan Send a message via Yahoo to dey_anjan
Default Tone Control
Stereo tone control with 2x10k
Hello Mile,
Please elaborate the difference between Post#52 & 209 and may you share the PCB.
Rgds
AD
help with single supply for two EQ/preamps lassoharp Power Supplies 3 9th July 2009 04:24 PM
HELP with PHONO and MIC preamps. P Lazkao Tubes / Valves 10 23rd June 2006 02:42 PM
measurement programs, mics and mic preamps. j.burtt Multi-Way 11 15th November 2005 09:08 PM
Power supplies in mic tube preamps JamMan Tubes / Valves 5 2nd November 2004 03:48 PM
mic preamps travis Solid State 7 20th May 2002 06:59 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
